Thread: led wiring help
Results 1 to 14 of 14
  1. #1 led wiring help
    ok so i bought some leds and now im trying to wire them up and im not sure if i have the right pieces, since i dont realy have a clue as to what im doing i furgured i'd ask,..i went to this website(Current limiting Resistor calculator for leds) and it told me that i need 220ohms and 1/2 watts(whatever that means)..and i just want to make sure im doing it right..on the website it asks for a voltage drop and on the package is just says foward voltage and im guessing thats its the same thing and a voltage drop..and when i do wire them up should i put the resistor on the voltage side or the ground side?
    ,thanks in advance
  2. #2 Re: led wiring help
    Pictures or make model of what you bought... then please tell us what you drive.
  3. #3 Re: led wiring help
  4. #4 Re: led wiring help
    Easiest thing to do is look up the color etc on google and you'll find a few sites that tell you what resistor to use.
  5. #5 Re: led wiring help
    thats what i did and thats the site that came up..so i guess thats right...whats the 1/2watts for?
  6. #6 Re: led wiring help
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    The 1/2 watt is the power dissipation rating for the resistor. A 1/2 watt resistor is going to be fairly large. I would look at trying to combine multiple LEDs in parallel to have the LEDs dissipate my power therefore letting the resistor disipAte less and it would be easy to wire for you!
    Infinity all around.
  7. #7 Re: led wiring help
    You can also combine 7 LEDs in series which would provide a perfect voltage for each of your LEDs.
  8. #8 Re: led wiring help
    Quote Originally Posted by chamilton89 View Post
    thats later but not for what these will be used for, the most i might use is 4
  9. #9 Re: led wiring help
    so if i wire 2 of them in series i would need a 220ohms resistor and a 1/2 watt resistor
  10. #10 Re: led wiring help
    No, if you wire them in series, you would need twice the voltage of one led. You would need a different resistor to comp sate fir throat voltage increase.
  11. #11 Re: led wiring help
    this is the set up the website gave me
    thats why i asked
  12. #12 Re: led wiring help
    Here is a good site that explains all of this. It's very simple and is just ohms law which asks voltage input voltage required and resistance of the led. Let me know if you need any more help!
  13. #13 Re: led wiring help
    im sure i will, but its not gonna happen for probloy another week..ill play around with it until i can throw it all together and ill post what i come up with and im sure there will be more questions
    thanks for your help
  14. #14 Re: led wiring help
    ok did another one hows 470ohms and 1/4watts..sound, better,,,i think i found what i was doing wrong
  1. wiring help
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:19 PM
  2. wiring help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-24-2010, 11:00 AM
  3. sub wiring
    By grand2000prixgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 02:37 AM
  4. Wiring or???
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-19-2009, 10:30 PM
  5. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
