Thread: Where to run power wire?
Results 1 to 20 of 22
  1. #1 Where to run power wire?
    ohio
    I have a 1997 grand prix, does anyone know where theres a spot to run my power wire through the firewall?
  2. #2 Re: Where to run power wire?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Passanger side firewall, low down. It goes under the passanger's feet under the carpet.
  3. #3 Re: Where to run power wire?
    May 2008
    McHenry IL
    vinnie is dead on push with a huge screw driver threw the huge rubber gromet type thing and youll find a way threw =]
  4. #4 Re: Where to run power wire?
    Toronto, ON
    I was about to ask the same question about the power wire. I have a 2000 GT. Is that grommet in the same place? I couldn't see it...perhaps I didn't pull the carpet back far enough.
    Lemme know....thanks.
  5. #5 Re: Where to run power wire?
    May 2008
    McHenry IL
    im pretty sure its there man pull carpet back pretty far its on the middle back side of the passenger side floorboard just take a huge screwdriver and tape the wire to it and stab it threw haha good luck =]
  6. #6 Re: Where to run power wire?
    Las Cruces, NM
    every year of our car has it.
  7. #7 Re: Where to run power wire?
    Toronto, ON
    Holy jeeze.....I think I am going to use an ice pick! That is some pretty thick rubber, man! haha
    Thanks for the help.
  8. #8 Re: Where to run power wire?
    May 2008
    McHenry IL
    i used a hammer and a huge standard screwdriver haha =]
  9. #9 Re: Where to run power wire?
    I used a stepper bit, and then custom made a grommet that fit around the
    wire and slid into the drilled hole. No problems...
    Oh and it is located on drivers side down low... Make sure you dont drill into the subframe. Drill further to the left than you think and you will be ok.
    Wiz, Wideband O2, 78mm T/B, P&P SC, SSIC, P&P LIM, 3", 1.8CCRR's, CC push rods, Custom covers, SLP headers, Meziere Water pump 3" Magnaflow, Race Tranny, 20" Concept One Wheels, Coilovers, BMR F&R suspension, Custom Body and Paint, Custom interior and sound.
  10. #10 Re: Where to run power wire?
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    you can pop out part of that and then poke through
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  11. #11 Re: Where to run power wire?
    Jersey
    a clothes hanger wire is my favorite tool for running amp wire, i ran new wire in this kids 00' grand prix and made a slit through the rubber groumet for the power wire so there wasnt a huge hole in the fire wall
  12. #12 Re: Where to run power wire?
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    i went through the pas. side where the door electronics come out then i went through the fender above the wheel, then pull it out right behind the front headlight, did this with the good old coat hanger!! its a fast and clean way to do it!! if u want pix ill post them!!
  13. #13 Re: Where to run power wire?
    Donating Users crshoveride's Avatar
    Pearl, MS
    that's what i did. it's like a 2 piece grommet. the innermost will pop out and then it just takes a screwdriver like everyone else said. it'll pop right through. that's how i did it.
    1998 Grand Prix GTP Stock for now mods to come soon. Alpine 9885 head unit, 2 JLW3V2 10s, 2 Jensen 650x2 amps, and Tsunami wiring all the way around.
    Ladies and gentleman take my advice. pull down your pants and slide on the ice
  14. #14 Re: Where to run power wire?
    SE Level Member Charged97's Avatar
    ATLANTA
    i drilled a hole on passnger side
  15. #15 Re: Where to run power wire?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by 99prixgt View Post
    did the same through the rubber...although i had to hella tape the wire to it...almost lost it but it came thru...like everyone said be sure to stick a nice sized screwdriver in there to open it up...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  16. #16 Re: Where to run power wire?
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    You would think these car manufacturers would think of making an accesories hole in the firewall for all the electronic gizmos these days. ARE YOU LISTENING GM
  17. #17 Re: Where to run power wire?
    Saraland Alabama
    Quote Originally Posted by Hayden View Post
    the problem is they don't want you adding any electronic gizmo, they want you to buy their top of the line junk, never aftermarket
  18. #18 Re: Where to run power wire?
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by archemedes View Post
    good-one
  19. #19 Re: Where to run power wire?
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    So if I am doing this right, I am having my wire actually running underneath the car for quite a bit am I right? I live in MN, and there is the dreaded salt and chloride on the roads, and I am little worried about my wire rotting away. Any suggestions other then running it through the pass door?
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  20. #20 Re: Where to run power wire?
    Aug 2008
    Fayetteville, NC
    personally if i could have ran mine under the car i would have but was just much easier under the carpet for me...i think ur wire would be fine but ur firewall is ur BEST bet.
  1. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
  2. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
  3. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  4. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
