Thread: KEy stuck in ignition
Results 1 to 19 of 19
  1. #1 KEy stuck in ignition
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    Anyone have their key get stuck in the ignition?
    I can turn it back enough to turn off everything (engine lights etc.) but it wont turn that last bit to release the key. this is a security issue too because it wont even let me lock the doors (yes with the key in) so that no one can just get in and start the car and drive off (i have a spare key so i wouldve locked the original without a problem), so for now my only fix is to either manually lock all the doors nd leave the key in the ignition, or to take a screw driver nd push it thru a hole in the bottom of the steering column which releases the key. But next time i try to turn the car off it gets stuck agaiin. I need a fix so i dont have to carry the spare key or a screwdriver around with me. Anyone?
  2. #2 Re: KEy stuck in ignition
    Charles City, IA
    Your ignition lock solenoid is junk pull it out. there is a write up on her on how to do it.
    SMGPFC Two Nipple General
  3. #3 Re: KEy stuck in ignition
    Nanuet, NY
    its junk? lol what it broke?
  4. #4 Re: KEy stuck in ignition
    GT Level Member neel2008's Avatar
    Huntington, IN
    mine does that, you can tilt the wheel up and reach up under the plastic and flip the little thing up and then you can turn the key back all the way and pull it out. I dont know how else to explain it better than that, i bought my car from my uncle and he showed me and Ive been doing it ever since. lol
    97gtp
  5. #5 Re: KEy stuck in ignition
    Charles City, IA
    yeah they stop working and the key just locks in, remove it and dont put a new one in and the key will always come out.
  6. #6 Re: KEy stuck in ignition
    Nanuet, NY
    lol seems like a pain in the ass to be honest lol this has happened before but not in a long time maybe lik 10 months, i dunno what happened to fix it
  7. #7 Re: KEy stuck in ignition
    Huntington, IN
    yea mine will work fine for like 6 months then not work for like 6 months etc. lol
    97gtp
  8. #8 Re: KEy stuck in ignition
    Nanuet, NY
    ok so u move the wheel all the way up? wheres the thing u flip up? did u do this while the car's on or did u turn it back then do it to get that last like quarter turn?
  9. #9 Re: KEy stuck in ignition
    Huntington, IN
    i shut the car off, then tilt the wheel all the way up, then I have room to slip my hand up under the column and flip this little thing up with my middle finger, its about as far up as I can reach. I know, kind of hard to explain. lol
    97gtp
  10. #10 Re: KEy stuck in ignition
    Nanuet, NY
    so u flip off ur car basically lol
  11. #11 Re: KEy stuck in ignition
    Huntington, IN
    kinda lol, when u look at the plastic under the steering wheel, you see this little round plastic piece about the size of a dime. its kind of behind that, so yea you have to reach up there kinda far, that's why you have to tilt it up all the way. but once you flip it up you can turn the key the rest of the way back and pull it out.
    97gtp
  12. #12 Re: KEy stuck in ignition
    mine had that same problem, but i didnt have to do anything like that,,it was a problem with my shifter not the lock, all i do is when it gets stuck i turn the key back on and i squeeze in the shift release until i hear a click from the instrument panel(where it shows what gear your in) then when i turn the key back it turns all the way bac and comes right out
  13. #13 Re: KEy stuck in ignition
    Donating Users
    South Deerfield, MA
    http://www.grandprixforums.net/i-can...tion-6277.html
    ^^^ Follow this. I had the same problem and this took care of it.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  14. #14 Re: KEy stuck in ignition
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    another way is tht little hole under the steering column u can stick a screw driver in there. stick it in there and push up then it will make the key come back...i had the same problem i just put a piece of foam in there but the only problem was tht u can take the key out when the car was in any gear when the car was off. but it works.
  15. #15 Re: KEy stuck in ignition
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    i just ripped it out lol
    works good because the system don't recognize that its in park so i leave it in neutral
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  16. #16 Re: KEy stuck in ignition
    When I had my 01GT I made the mistake of taking my car in to get it fixed, they charged me $400 for a new shifter with labor, I'm like why can't you just replace the solenoid? That must only cost $5, they told me it could not be done that way, ****ing pricks, wish I would have known about this site before that happened.
  17. #17 Re: KEy stuck in ignition
    SE Level Member Reddcurrlz's Avatar
    Feb 2009
    Panhandle of Florida
    Oh WOW Mine does that too. Sometimes, I start it up, put it in reverse and then pull it back up into park after I move a lil bit, then turn it off and it releases. But if you notice, when you're shifting into Park, you'll not only feel the shifter real loose but also, the lights on the dashboard where the PRND stuff is, the light stays on. I never figured out what was wrong with it, but I deal with it. U just gotta work it. WORK IT MAN. It'll eventually come out, that's the only thing I've noticed works on mine.
    Proud owner of a 2000 sexy, dark green, GPGT, 3800 V6. Still all stock
  18. #18 Re: KEy stuck in ignition
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    Just take the lower column cover off,remove the solenoid and throw it in the trash. I have done this to my last 2 grand prix's.
  19. #19 Re: KEy stuck in ignition
    I had a guy tell me all the shifters in the junk yards were gone because of this issue... I lol'd.
  1. Key stuck in the ignition
    By Gearhead Garland in forum General Tech Discussion
    Last Post: 01-31-2012, 06:32 PM
  2. Key stuck in ignition.
    By at2smithjason in forum General Tech Discussion
    Last Post: 03-31-2010, 06:16 PM
  3. key stuck in ignition....
    By fst in forum General Tech Discussion
    Last Post: 01-21-2010, 06:06 PM
  4. key stuck in ignition?
    By jaketrey32 in forum General Tech Discussion
    Last Post: 05-15-2009, 05:28 PM
  5. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
