Thread: Capacitor voltage readout
Results 1 to 16 of 16
nik12937 Capacitor voltage readout 02-14-2011, 03:45 PM
matt5112 Re: Capacitor voltage readout 02-14-2011, 03:46 PM
I800C0LLECT Re: Capacitor voltage readout 02-14-2011, 05:40 PM
nik12937 Re: Capacitor voltage readout 02-14-2011, 10:36 PM
eddie97gt Re: Capacitor voltage readout 02-15-2011, 12:24 AM
matt5112 Re: Capacitor voltage readout 02-15-2011, 12:59 PM
I800C0LLECT Re: Capacitor voltage readout 02-15-2011, 02:45 PM
nik12937 Re: Capacitor voltage readout 02-15-2011, 08:05 PM
1LoudGrandPrix Re: Capacitor voltage readout 02-15-2011, 10:36 PM
I800C0LLECT Re: Capacitor voltage readout 02-15-2011, 10:43 PM
matt5112 Re: Capacitor voltage readout 02-16-2011, 12:31 AM
nik12937 Re: Capacitor voltage readout 02-16-2011, 05:30 PM
KeithGTP03 Re: Capacitor voltage readout 02-16-2011, 06:12 PM
dpzelenak Re: Capacitor voltage readout 02-16-2011, 06:31 PM
I800C0LLECT Re: Capacitor voltage readout 02-16-2011, 10:40 PM
1LoudGrandPrix Re: Capacitor voltage readout 02-18-2011, 03:30 PM
  1. #1 Capacitor voltage readout
    GTP Level Member nik12937's Avatar
    Pennsylvania, USA
    I don't need to know how I need/ don't need a cap in my system, I have one so I may as well use it.
    My cap has a volt readout on the top and when my car is on it's lately been reading about 12.6-13.6v, could that indicate a problem with my alternator, etc? It used to read right around 14v unless I turned my subs up. The reason I ask is when I turn up my system, my lights dim, and I'm afraid I may be slowly burning out my alternator.
    I'm upgrading my Big 3 shortly to see if maybe that will help...
  2. #2 Re: Capacitor voltage readout
    13.6 from a heat soaked alt is good.
    below 13 is bad...
    Try better sub/cap ground.
  3. #3 Re: Capacitor voltage readout
    Feb 2009
    Virginia
    grounds could be corroding.
    11 is louder than 10!
  4. #4 Re: Capacitor voltage readout
    Pennsylvania, USA
    I'll check the ground I'm using for the cap because it's in an... interesting spot (behind the bolts that hold the rear seat "locks" in place).
    As soon as I get some new battery terminals I'mm do my Big 3 and post an update in this thread (:
  5. #5 Re: Capacitor voltage readout
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    ditch the cap and ger a second battery , there are a high discharge and recharge device , they will actually put the alternator under a bad strain , battery on the other hand has alot left in reserve . and have you done 4ga from the back of the alternator straight to the battery ? that helps alot too . just make sure you use good wire and ring terminals . these are some of the tips from jl audio tech dept from back in the day
  6. #6 Re: Capacitor voltage readout
    They dont put out any amperage till the system is already dangerously low in voltage.
  7. #7 Re: Capacitor voltage readout
    Feb 2009
    Virginia
    Extra batteries, batt/caps, and caps...are stupid when the engine is running. Even when it's off...the only one that helps is a battery. Batt/caps are dumb too, unless spl maybe?
  8. #8 Re: Capacitor voltage readout
    Pennsylvania, USA
    I still don't understand why people say caps are worthless. It's a capacitor, it charges and discharges when needed, that's all, why aren't all other capacitors worthless?
    After putting my cap on my headlights didn't dim as much and my bass sounded cleaner...
  9. #9 Re: Capacitor voltage readout
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    they are usless btw turn down your gains
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  10. #10 Re: Capacitor voltage readout
    Feb 2009
    Virginia
    Your lights didn't dim as much because you added a ground. Capacitors only discharge once voltage has dropped below ~12.6V. A 1 farad capacitor can only support an audio system that presumes "1000 watts" for a fraction of a second. After that, it becomes an additional load but it only charges once the system is above ~12.6V. Caps are worthless because a well built power supply in your amplifier has exactly what it needs to support it's function.
    http://www.grandprixforums.net/upgra...tml#post298578
    Btw, you can buy a few 1 farad caps for a few bucks + shipping. You don't get the ginormous pretty cases that companies like Rockford Fosgate might give you but I guess that makes it more manageable too? It's your money to throw away...
    http://www.mcmelectronics.com/produc...LAID=220396964
  11. #11 Re: Capacitor voltage readout
    Caps are only useful if you add them to the power rails inside the amp.
    You can boost the burst power rating of an amp that way.
    But only if the design can take advantage of it.
    Note thats the BURST rating which is commonly spec'd at 30 ms.
  12. #12 Re: Capacitor voltage readout
    Pennsylvania, USA
    I got the cap for free (5 farad), after reading that thread, thank god...
    Well, hopefully my Big 3 helps the dimming issue I'm having, if not then I'll have to ask where I should get a HO alternator from, because I looked several times, and I can never find any good sites...
    And here's my amp if anyone's curious: Kenwood KAC-9104D Mono subwoofer amplifier 900 watts RMS x 1 at 2 ohms at Crutchfield.com
    Powering two Kicker L7's (the original L7's, not the loud, boomy **** ones they offer nowadays) in a ported enclosure tuned to 33Hz (if you think it's probably big... it's HUGE).
    Not sure what the difference is between 9104 and 9105, but I've got the discontinued one...
  13. #13 Re: Capacitor voltage readout
    Houston
    Quote Originally Posted by nik12937 View Post
    If you find an HO alt, let me know. I tried to find one about 6 mos. ago when my alt went out. Could not find one.
  14. #14 Re: Capacitor voltage readout
    yea im with keith, i've been looking for one too, and i have the dimming problem and when my cars idleing and i turn the bass up it drops the idle rpm, from like 7 or 8000 to 4 to 5000, and i was told this was very bad
  15. #15 Re: Capacitor voltage readout
    Feb 2009
    Virginia
    Don't need an h.o. alternator for that setup. There's a guy on gpona who went to world finals in his spl class using stock alternator and sine waves for 2kw output from his amplifier running off a battery. Just need better grounds and 4awg wire minimum.
  16. #16 Re: Capacitor voltage readout
    Cedar Rapids, IA
    DB Electrical - Grand Prix
    i have the 220A its the cheapest alt you will find
  1. Ideal values readout
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-07-2010, 01:19 PM
  2. Repeated TCC lock/unlock with no PCS readout
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2010, 11:02 AM
  3. amp & sub combo... capacitor?
    By GTPjunkie in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 10:49 AM
  4. how do i know if i need a capacitor?
    By 94GTRoyalty in forum Audio, Security & Visual Electronics
    Last Post: 08-27-2008, 07:41 AM
