Thread: Charging System Failure Help??
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Charging System Failure Help??
    Houston
    No I mean an electrical system load test. Not an alternator test.
  2. #22 Re: Charging System Failure Help??
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    oh okay ya ill have to check into tht unless someone else may know a problem...
    thanks tho
  3. #23 Re: Charging System Failure Help??
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    My 2005 was doing the same thing when switching from high to low beams and back. I changed my battery(it was 6 years old) and the problem has not occured since then. That has been about 3 weeks ago. I was thinking mabey my HID's or led lights were causing some problem but luckily the problem resolved with the new battery. good luck
  4. #24 Re: Charging System Failure Help??
    Pittsburgh, Pa
    ya i got hids to idk if the problem occured before them tho not sure
  5. #25 Re: Charging System Failure Help??
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    I have gotten this light very briefly twice now.Man these cars are really funny. I have all kinds of weird stuff that happens sometimes. I guess they are small flaws in the design of the car overall. I have had stuff happen and had it checked by the shop no codes but the problem existed. It takes alot of patientce and time to maintain a grand prix.
  6. #26 Re: Charging System Failure Help??
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    11 MONTHS old
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  7. #27 Re: Charging System Failure Help??
    Nov 2011
    fairbanks, ak
    not anymore.
  8. #28 Re: Charging System Failure Help??
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Another note on this problem -- it is also very commonly caused by improper battery terminal connections. Clean your terminals and check/tighten the connections regularly; I would suggest every 4-6 months, especially in the cold seasons.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #29 Re: Charging System Failure Help??
    Pennsylvania
    04 and 05 have the alternator with the built-in clutch and they tend to fail.
    Also, it's time for all '05's to get new batteries.
  10. #30 Re: charging system failure.
    Nov 2011
    fairbanks, ak
    Awesome advice and thank you. The battery is no more than 2 years old so i think im covered except it is an optima red top so would that cause any problems? Also the terminals were cleaned and tightened and corrosion inhibitor was added about 3 months ago so i will double check, you cant always trust the dealership. But as of now i havent had a repeat of the light and have no problems. i have a diagnostic program on my comp. and i ran it while i drove and nothing out of the ordinary. idk i still love my baby.
  11. #31 Re: Charging System Failure Help??
    Jun 2012
    I've had the same problem the Charging System Failure came on I just want to know if I should check anything before I R&R the alternator. I tested it and came back good at local parts store, low 14v high 14.56v but when its on the car and I touch the back post and bat terminal with a multimeter I only get 6v. I just want to cover my bases before handing over $200. I'm new to Grand Prix just bought this one from a friend he had it and i always liked it. It's a 2004 GT2.
    PS: batt is good
  1. Charging Sytem Failure Warning
    By 07GP316 in forum General Tech Discussion
    Last Post: 02-20-2011, 01:18 PM
  2. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  3. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  4. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
  5. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
