Thread: Is this all i would need?
Results 1 to 10 of 10
  1. #1 Is this all i would need?
    JDM XENON 9007/HB5 8000K HEADLIGHT CONVERSION HID KIT - eBay (item 200569305022 end time Feb-01-11 11:54:45 PST)
    I've read multiple threads and articles but im still not sure. and for less then 100 bucks, why not
  2. #2 Re: Is this all i would need?
    Kansas
    Yes. You could upgrade with a relay harness tho
    SOLD 1999 GT Silvermist TS
  3. #3 Re: Is this all i would need?
    ok great, were can i get a relay harness from?
  4. #4 Re: Is this all i would need?
    Kansas
    ebay also
    9007 relay harness
  5. #5 Re: Is this all i would need?
    and the harness is just like a plug and play type
  6. #6 Re: Is this all i would need?
    Kansas
    Yes. But you need to wire it to a constant 12 volt source.. ie your battery
  7. #7 Re: Is this all i would need?
    Ocala, FL
    Skip that one, you can get them for far leas than that.
    Check ddmtuning.com
  8. #8 Re: Is this all i would need?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Wbodystore is 109 for everything including hrness
    http://www.wbodystore.com/grandprix/...Kit-p-145.html
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  9. #9 Re: Is this all i would need?
    Quote Originally Posted by codyAK View Post
    Check ddmtuning.com
    i checked them out and i wasn't impressed, by the time your done its still around the same price if not alittle more
  10. #10 Re: Is this all i would need?
    Quote Originally Posted by djrepoman View Post
    W Body Store
    thanks for the link, if i was planning on keeping this housings i would go with these, but i may get them for another car i got when the moneys right..
