Thread: Interior LIghts
Results 1 to 16 of 16
  1. #1 Interior LIghts
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    When putting led lights under dash which wire do u splice it into on the car its on a 2005 grand prix.
  2. #2 Re: Interior LIghts
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    What kind of LEDs you putting in which requires you to splice into a power wire?
  3. #3 Re: Interior LIghts
    Pittsburgh, Pa
    the led strips tht are double sided tape tht u stick on under dash
    dunno wht wire unless i can jump outta a fuse in the fuse box
  4. #4 Re: Interior LIghts
    Pittsburgh, Pa
    like i see u put them in the coin tray and cup holders which wire u hook in to
  5. #5 Re: Interior LIghts
    Nov 2009
    Quote Originally Posted by 2005GrandPrix View Post
    For the ground.
    For the power.
    Current setup minus my LEDs in my footwells.
  6. #6 Re: Interior LIghts
    Missouri
    Quote Originally Posted by csssaint12 View Post
    Love the LEDs in the vents
    SMGPFC Member #7.5
  7. #7 Re: Interior LIghts
    Nov 2009
    Quote Originally Posted by RegorHtims View Post
    My cousin doesn't like them because you can see the LEDs but I love them and I don't mind catching glimpses of them. Super easy mod too.
  8. #8 Re: Interior LIghts
    Missouri
    Yeah that would be so easy to do.... I wouldn't even need a how to...but I mean.... maybe some other people would want to do it too... and they might.. need a how to.. yanno....
    SMGPFC Member #7.5
  9. #9 Re: Interior LIghts
    Pittsburgh, Pa
    thanks. is tht in the fuse panel on the passenger side? and what fuse did u go outta?
  10. #10 Re: Interior LIghts
    Nov 2009
    That is from the passenger side fuse panel. I can't remember exactly what fuse I went out of because the fuse slot was empty.
  11. #11 Re: Interior LIghts
    Pittsburgh, Pa
    oh okay do they come on and off with ur key?
  12. #12 Re: Interior LIghts
    Nov 2009
    No. I have them wired to a switch and the power only comes on if the key is on the accessory or on position.
  13. #13 Re: Interior LIghts
    Pittsburgh, Pa
    but if i dont put them on a switch they should come on and off wit key?
  14. #14 Re: Interior LIghts
    Nov 2009
    Ya they should come on and off with the key but the only problem with that might be if you get pulled over and wouldn't be able to turn off.
  1. Interior lights not working
    By jmanrta in forum General Tech Discussion
    Last Post: 11-30-2010, 12:37 PM
  2. LED interior lights
    By joliver2011 in forum Visual/Body Modifications
    Last Post: 02-14-2010, 09:45 PM
  3. problem with the interior lights?
    By riseagainst4288 in forum General Tech Discussion
    Last Post: 07-24-2009, 08:37 PM
  4. Interior lights from red to blue
    By robahr24 in forum Visual/Body Modifications
    Last Post: 08-26-2008, 04:46 PM
  5. Interior Lights:(
    By RichCresci in forum General Tech Discussion
    Last Post: 07-08-2008, 11:29 PM
