Thread: DRL fog light diodes
Results 1 to 7 of 7
  1. #1 DRL fog light diodes
    Nov 2010
    St Louis
    Hey guys,
    looking to wire remove the DRL diode and wire up the DRL as the fog lights.
    however, as per DRL circuit Re-route to fog lamps
    I cannot find the 1N400x diodes and have used google shopping, radioshack, 247components.com and still cannot find this part number.
    Does anybody know a suitable substitute or a place to get them?
    -Ryan
  2. #2 Re: DRL fog light diodes
    Dec 2008
    Lawndale, CA
    Look into any of the following: 1N4001-1N4007.
  3. #3 Re: DRL fog light diodes
    S Texas
    mouser.com
    If they don't have it or can't find it you're probably SOL.
    As a start...
    http://www.mouser.com/Search/Refine.aspx?Keyword=1n400
    2004 GTP COMP-G
  4. #4 Re: DRL fog light diodes
    Nov 2010
    St Louis
    ......1N400x.... x being a variable.... rofl
  5. #5 Re: DRL fog light diodes
    Nov 2010
    St Louis
    everything I can find is only a 1 amp diode though :-\
    I need 1.5 amp right?
  6. #6 Re: DRL fog light diodes
    Dec 2008
    Lawndale, CA
    You will be fine with any of those.
  7. #7 Re: DRL fog light diodes
    Nov 2010
    St Louis
    oke doke, thanks guz. I'll post back if there's any problems
  1. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
