Thread: 12's cut off
Results 1 to 20 of 27
  1. #1 12's cut off
    SE Level Member Tha Ghost's Avatar
    Dec 2010
    La Victoria Ranch, Tx.
    I put a kicker 300 watt amp, with some quantum cozmic series 12's with tha stock radio, and they sound pretty good but they cut off, after a while of bumping the amp just turns off and like 30 seconds later tha bass just turns on.
    Mustangs are like tampons...every pvssy has one!
  2. #2 Re: 12's cut off
    Donating Users onetyme77's Avatar
    texas
    sounds like the amp is going into protection
  3. #3 Re: 12's cut off
    Dec 2010
    yes but i dont know y it does that.
  4. #4 Re: 12's cut off
    SE Level Member 01PonGPGT's Avatar
    Iowa
    thats why you dont buy kicker
  5. #5 Re: 12's cut off
    thermal protect
    amp being run at too low a nominal impedance or their is insufficient airflow over your amp.
  6. #6 Re: 12's cut off
    texas
    basicly what matt (oh techincal almighty lol) is saying is...you amp is too small. it will push (play) your subs, but after playing for a certain amount of time at certain levels, it goes into protection aka shuts off to stop from burning up. and there's nothing wrong with kicker. get what you like but make sure you have enough power to push them at the volume u want to play them. (i would suggest some audio brands, but its really to each its own) so either turn the amp down (turn the gain down) or get a bigger amp
  7. #7 Re: 12's cut off
    Feb 2009
    Virginia
    Model of your amp? If it's a two channel and you're running bridged then you're load is too low...as said stated already.
    11 is louder than 10!
  8. #8 Re: 12's cut off
    my amp can put out 1500 watts RMS as per turbo trav..............
    yet i can still get it to hit thermal protect after 40 minutes of beating on the sub with consistant bass tracks in the dead of summer and i'm probably only running 400-800 RMS.
    Sub can handle a 1 kW too.
    Basically it needs some sort of cooling.
    But i have a better solution, sell it
  9. #9 Re: 12's cut off
    Feb 2009
    Virginia
    I don't know what you guys do...I haven't hit thermals yet err...I take that back. My kenwood in highschool did in the heat of summer.
    Kenwood KAC-848
    People don't have thought out installs?
  10. #10 Re: 12's cut off
    texas
    [QUOTE=I800C0LLECT;487644]in the heat of summer.
    QUOTE]
    that is why i think the amp is too small, its 300watts on two 12's (in the WINTER time), Ive had this happen many of times because i couldnt afford a bigger amp.
  11. #11 Re: 12's cut off
    Feb 2009
    Virginia
    Um. Turn your gains down? The amp was designed to function within a certain performance envelope. Some how you're working it outside of that. I blame install and tuning. Howeer, if it's an older amp it could be something else....
  12. #12 Re: 12's cut off
    Jul 2008
    sumter,south carolina
    i have a DB 600X1 ill sell ya for a decent price.
    02 GTP with mods 05 GP for DD
  13. #13 Re: 12's cut off
    Dec 2010
    I'm already getting a 4000 watt amp so it could push bad ass.
  14. #14 Re: 12's cut off
    Jul 2008
    What kind is it? These super high wattage amps are usually garbage. They sell them by claiming high wattage.
  15. #15 Re: 12's cut off
    texas
    Quote Originally Posted by Tha Ghost View Post
    check the rms wattage on amps, not the max.
  16. #16 Re: 12's cut off
    the max on mine is 5500 W, does that make me the winner?
  17. #17 Re: 12's cut off
    Jul 2008
    My memphis 500D on my DD subs demolished my tail lights. What do I win?
  18. #18 Re: 12's cut off
    Feb 2009
    Virginia
    really?
  19. #19 Re: 12's cut off
    Dec 2010
    its 4000 rms and a 2 channel
  20. #20 Re: 12's cut off
    then you must have paid $1500 + for it
cut
