Thread: LED head lights
Results 1 to 11 of 11
  1. #1 LED head lights
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I've been wondering for a while if there was any LED head light bulbs in the market and I came across this product:
    9007 18 SMD LED WHITE LIGHT BULB (PAIR)
    Does anyone know how good they are compared to standard and HIDs? I would prefer these over HIDs since they consume less power heat up less and don't seem to need any more components like the ballasts.
  2. #2 Re: LED head lights
    they look like they'd be a candle compared to your stock headlights
  3. #3 Re: LED head lights
    Banned
    Sioux Falls, SD
    I wouldnt trust them
  4. #4 Re: LED head lights
    Mexico
    Yeah it looks like they may not have enough power. I might buy a set off ebay and try to swap both head light and fog lamps to see if they make a decent light all together. They are so cheap, that I wouldn't mind trying I guess.
  5. #5 Re: LED head lights
    Banned
    Sioux Falls, SD
    save your money and get a HIDS kit from DDMtuning for the same price
  6. #6 Re: LED head lights
    LEDs arent bright at distance. i havent seen a set that would work as a headlight bulb.
  7. #7 Re: LED head lights
    SE Level Member K Dawg ONE's Avatar
    Dec 2010
    Windsor, Ontario, Canada
    I had HIDs in my lows on my blazer and ran those bulbs in my high beam spot since I dont use the highbeams. Figured since my hbs were also my DRL's, it would look very cool, kinda audi-ish.
    Well, not enough resitance to use as drls without a relay and even when physically switched on, they were barely noticable.
    Kris Creed | 'GM-Pro Certified' Sales Consultant | GUS REVENBERG CHEVROLET-BUICK-GMC | Windsor, Ontario, Canada | 800-291-1117 ext. 177
  8. #8 Re: LED head lights
    GTX Level Member Confusingboat's Avatar
    Minnesota
    There's no way those will provide sufficient output. My switchbacks have 30 SMDs in each color and even that's not enough to provide enough light. Until they come out with bulbs that have like 500 SMDs there won't be any LED bulbs that provide sufficient amounts of light.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #9 Re: LED head lights
    I'll give you a hint, I use a set of those "LED" bulbs in my high beams....for turn signals
    YouTube - Grand Prix Lighting setup
    First couple of seconds in the video to give you an idea
  10. #10 Re: LED head lights
    Dec 2010
    Quote Originally Posted by DrunkietheBear View Post
    Could you tell me more about your outside door handles? BADASS!
  11. #11 Re: LED head lights
    Norristown, PA
    Drunkie your lighting setup is the nicest I've seen, I can't give you enough props.
    And to the OP, get hids, there cheap and easy to install. You get the color effect you want and decent output in stock headlights. There the smartest option, don't waste money on LEDs unless there going in your turn signals.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 0
    Last Post: 03-07-2010, 09:14 PM
  3. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  4. head lights
    By noom14921992 in forum Visual/Body Modifications
    Last Post: 10-18-2009, 01:42 PM
  5. head lights
    By Brent Schmerge in forum Shops and Community Heroes
    Last Post: 09-08-2009, 05:51 PM
