Thread: Heads Up Display
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Heads Up Display
    Quote Originally Posted by Andrew_99GTP View Post
    If you wire it it like the color codes say it works fine, just your volume turns up faster. That is the only problem.
    actually wiring high level outputs into the low level inputs of the BOSE amp greatly reduces the sound quality and messes up the crossover points. Since the bose speakers are perfectly matched to the bose amp, changing the crossover points makes a decent sounding system sound horrible.
  2. #22 Re: Heads Up Display
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by notladstyle View Post
    I guess I wired mine in by matching up the colors and it sounded fine to me, and my friend has one wired in like that and it sounds fine also. But personally I would splice in the RCA's if you are keeping the bose amp.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #23 Re: Heads Up Display
    If your gettin engine noise through your speakers just install a noise filter behind the HU. I had that problem, installed the filter and now no more engine noise!!!
  4. #24 Re: Heads Up Display
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by pyro_4_life41387 View Post
    didnt recall that that was a symptom he was having, but hey thanks for the reminder tip
  5. #25 Re: Heads Up Display
    lol sorry bout that guys, i was switching between a couple forums and posted the wrong reply! my bad
  1. Stock HU display.
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2008, 02:47 PM
  2. gtp cylinder heads
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:29 AM
  3. heads for a gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2008, 11:21 PM
  4. display flashing
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2008, 04:43 PM
