Thread: SES light burnt out. How to change it
Results 1 to 9 of 9
  1. #1 SES light burnt out. How to change it
    Nov 2009
    Sheridan,Indiana
    Can someone tell me how to change out the light bulb that lights the service engine soon indicater. Please give part numbers if you can and a picture of the area the light is located. Thanks alot.
  2. #2 Re: SES light burnt out. How to change it
    Sure it's a ... oh wait.. it might be a... or it's a...
    Please tell us what you drive. Year and model.
  3. #3 Re: SES light burnt out. How to change it
    Nov 2009
    Sheridan,Indiana
    Oddly enough its a GRAND PRIX. 2000 GTP
  4. #4 Re: SES light burnt out. How to change it
    I'm not 100% sure because I've never pulled the GP cluster apart. Sylvania lists these as fitting your car. I'm thinking the blinker or high beam would be the right bulb. Mostly cluster bulbs are pretty standard across the cluster.
    Auto Lamp Replacement Guide - Results
    Print out the list and find them at your nearest retailer.
    Stay informed about new products from SYLVANIA. Sign up with one of our newsletters and let us help you with your needs.
    When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
    2000 PONTIAC Grand Prix
    High & low beam headlamp
    9007
    9007SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
    9007ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
    9007EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
    9007XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
    9007CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
    Parking light
    3457A
    3457ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Front turn signal
    3457A
    Rear turn signal
    3057
    3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Tail light
    3057
    Stop light
    3057
    High mount stop light
    1141
    1141LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Fog/Driving light
    880
    880ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
    License plate
    194
    194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Back up light
    3156
    3156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    3156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Front sidemarker
    194
    Rear sidemarker
    194
    Ash tray
    194
    Glove box
    194
    Map light
    168
    168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    212-2
    212-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Dome light
    562
    562LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Step/Courtesy light
    168
    194
    Trunk/Cargo area
    912
    912LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Under hood light
    561
    561LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Instrument-general
    194
    37
    37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    PC195
    PC74
    Hi-beam indicator
    PC195
    Automatic transmission indicator
    194
    37
    Directional signal indicator
    PC74
  5. #5 Re: SES light burnt out. How to change it
    Charles City, IA
    The dash trim panel just pulls out. Then unplug the fog light switch. Move panel out of the way, then there are 2 screws that hold in the cluster pull those out remove cluster, then bulbs just twist out. Twist out the bulb reinstall cluster drive to auto store and have them match the bulb if there is no number on it.
    SMGPFC Two Nipple General
  6. #6 Re: SES light burnt out. How to change it
    Nov 2009
    Sheridan,Indiana
    So, are these bulbs just like the bulbs in the DIC? Thanks guys for the above info!!
  7. #7 Re: SES light burnt out. How to change it
    Feb 2008
    Edit: (I FAIL) Might be a good time to upgrade the entire dash to LED!!
  8. #8 Re: SES light burnt out. How to change it
    Jul 2010
    Coquitlam,BC,Canada
    The bulb is a #73; just changed mine a few months ago.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: SES light burnt out. How to change it
    Feb 2008
    Quote Originally Posted by Bronco Boy View Post
    DANG! I hate those tiny bulbs... I'll edit my previous post so no one gets confused. Thanks for the correction!
  1. Burnt out light in shifter box
    By pghtattooer in forum General Tech Discussion
    Last Post: 02-21-2011, 03:26 PM
  2. change oil soon light
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 02:38 PM
  3. change oil light.
    By Ironwarrior in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-05-2009, 03:44 AM
  4. Change oil soon light!
    By MARKS99 in forum General Tech Discussion
    Last Post: 07-20-2009, 07:44 PM
  5. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
