Thread: build me a new stereo - 2000 GP GT
Results 1 to 8 of 8
  1. #1 build me a new stereo - 2000 GP GT
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I think my stereo is going in my 2000 grand prix GT. The audio changes tones depending on the volume of the radio. bass fades in and out..
    Help me build a new stereo system.. I have HUD if that matters, and I want to preserve my steering wheel controls. Cd player and an IPOD hookup would be great.. I have newer speakers, which aren't the best so I guess I could put new ones in. Subwoofer would be nice.. Please make recomnedations and post links.
    Also, if you can post pictures of your setup, that would be great....
  2. #2 Re: build me a new stereo - 2000 GP GT
    GT Level Member jakewet28's Avatar
    Cincinnati
    You should buy my sub box that I made that I'm selling. it's for 2 15's but it's sweet looking and fits perfectly
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  3. #3 Re: build me a new stereo - 2000 GP GT
    Nov 2009
    chicago
    Nobody has ideas?
  4. #4 Re: build me a new stereo - 2000 GP GT
    I have lots of ideas.
    but no one likes them.
  5. #5 Re: build me a new stereo - 2000 GP GT
    Kansas
    You listen to matt or I800 they know their ****, there are other people here that know a lot to but them two are the top of my list to talk to when it comes to audio.
    SOLD 1999 GT Silvermist TS
  6. #6 Re: build me a new stereo - 2000 GP GT
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Quote Originally Posted by Gafford44 View Post
    This. Anyone can rattle a trunk, but not many can make a setup sound beautifully. They definitely know what's up.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  7. #7 Re: build me a new stereo - 2000 GP GT
    Feb 2009
    Virginia
    Thanks guys...Matt is probably more inclined with function but I like my audio to look nice and discreet so I'm always trying different ideas that are based on theories.
    Unless you give me an idea of what you want for an install I don't know where to start?
    I've had one idea I've been wanting to try that is basically a keep it simple approach so that tuning is much simpler and less variables over all.
    The idea is to use a full range driver matched with a mid-bass and sub woofer vs. the classic tweeter, mid, sub. This application will make it MUCH simpler for tuning and adjustment as well as install since the most crucial frequencies are grouped together within one driver. However, install is much more important with this too. I would place the full range driver either on the dash or hanging from the A-pillar. You essentially want to derive a radius using your crossover point on this full range driver. Once you plug in the Fs of the speaker and spit out a radius that is what you will use to construct your sphere to hold the actual speaker. The point of this is to reduce diffraction which will help get rid of a lot of issues with reflections as well.
    Anyways, build all that...hang it from the a pillar or hide in the dash, somehow...your call. if you place it in the dash make sure it's as close as possible to the apex of the windshield and dash. It has to do with reflections again.
    Once you're done there get a nice beefy midbass to reach about 60hz but preferably 40hz. I think matt found a nice mid-bass that's ~7inches. Again, INSTALL IS VERY IMPORTANT!!! 90% install and 10% hardware = sound. If you just hang speakers from a hangar don't expect much.
    Now you can hide your sub in your vehicle ANYWHERE you want. Psychoacoustics play a big part in our ability to understand and process sounds. So essentially anything below 80hz is hard to localize by our ears unless it's causing vibrations. My sub can be seen in my profile pictures and nobody knows it's in my trunk. Most people think my mids are creating all the sub frequencies.
    But anyways...that's a quick run through of an idea I'd like to try. Kind of burned out on swapping hardware so it probably won't ever happen. There's downsides to full range drivers that Matt will make sure you know about One of them is lack of sensitivity. However, you make up for this through the fact that it's a near field environment and shouldn't be a terrible problem. I guess I'm done for now...i'll elaborate more if people have questions.
    FYI...I'm not big on SPL or high output. My audio has hit 133db on music C-weighted. I'd only play it that loud for maybe 5 minutes. I like my hearing. The sad thing is that when your audio is tuned right you never wanna stop cranking and usually don't know how loud it is since it doesn't hurt your ears. Poorly tuned systems will hurt your ears at even 100 decibels.
    11 is louder than 10!
  8. #8 Re: build me a new stereo - 2000 GP GT
    depends on the volume levels you're looking to achieve.
    Full rangers are ideal, better phase response. But if you keep the speakers on axis, you should minimize the window up/down effect.
  1. Putting Factory Stereo Back In 2000 gp
    By MysticStyl3z in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 03:51 PM
  2. $1500-2000 for build
    By Ascheymed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2010, 12:21 PM
  3. NO CLUE: Adding AUX plug in for Ipod in stock bose stereo 2000 gp
    By sirpig34 in forum Audio, Security & Visual Electronics
    Last Post: 09-10-2009, 08:55 AM
