Can someone tell me how to change out the light bulb that lights the service engine soon indicater. Please give part numbers if you can and a picture of the area the light is located. Thanks alot.
Sure it's a ... oh wait.. it might be a... or it's a...
Please tell us what you drive. Year and model.
Oddly enough its a GRAND PRIX. 2000 GTP
I'm not 100% sure because I've never pulled the GP cluster apart. Sylvania lists these as fitting your car. I'm thinking the blinker or high beam would be the right bulb. Mostly cluster bulbs are pretty standard across the cluster.
Auto Lamp Replacement Guide - Results
Print out the list and find them at your nearest retailer.
Stay informed about new products from SYLVANIA. Sign up with one of our newsletters and let us help you with your needs.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
2000 PONTIAC Grand Prix
High & low beam headlamp
9007
9007SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9007ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9007EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9007XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9007CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
3457A
3457ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3457A
Rear turn signal
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3057
Stop light
3057
High mount stop light
1141
1141LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
880
880ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
License plate
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
3156
3156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
194
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
212-2
212-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
562
562LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
168
194
Trunk/Cargo area
912
912LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Under hood light
561
561LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
194
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
PC195
PC74
Hi-beam indicator
PC195
Automatic transmission indicator
194
37
Directional signal indicator
PC74
The dash trim panel just pulls out. Then unplug the fog light switch. Move panel out of the way, then there are 2 screws that hold in the cluster pull those out remove cluster, then bulbs just twist out. Twist out the bulb reinstall cluster drive to auto store and have them match the bulb if there is no number on it.
So, are these bulbs just like the bulbs in the DIC? Thanks guys for the above info!!
Edit: (I FAIL) Might be a good time to upgrade the entire dash to LED!!
