Thread: Problem with Stock Speakers
Results 1 to 3 of 3
  1. #1 Problem with Stock Speakers
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    My two front door speakers fade in and out. Sometimes they work sometimes they dont. I can bump my driver side door and it sometimes comes on.
    Bad wiring? Should i pop off the door panels and check the wiring? or am i looking at replacing my two speakers?
    How hard is it to take off the door panels and put them back on?
    Thanks guys
  2. #2 Re: Problem with Stock Speakers
    Charles City, IA
    Probably the connection at the speaker to remove the panel there are 2 screws by the handle then maybe two more under the window switches and the door reflector. Then the rest is just body clip.
    SMGPFC Two Nipple General
  3. #3 Re: Problem with Stock Speakers
    Minnesota
    I have an 04, but had the same issue with an aftermarket speaker in my driver's side door. Turned out to be a loose connection that eventually worked its way completely off the speaker terminal. I modified the connection to make sure it is firm, and the problem is solved. I'm not sure how much you can really do about the quality of the connection with the OEM plug on there, but you might be able to bypass/rewire it if your handy with a soldering iron.
  1. Can I use the stock wiring for new speakers?
    By jstevanus in forum Audio, Security & Visual Electronics
    Last Post: 05-10-2010, 07:20 PM
  2. Problem With Back Speakers
    By Gmohre001 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 04:39 PM
  3. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
