Thread: electrical issues
Results 1 to 12 of 12
  1. #1 electrical issues
    SE Level Member toastisdead's Avatar
    Nov 2010
    canton, ohio
    I have a 1998 grand prix gt and im having electrical issues the heater only runs on the number 5 setting any time i turn it on to the 1 2 3 or 4 settings the headlights shut off but the fogs and running lights stay on i did replace the headlight switch the heater switch and the heater regulater and still have issues can some atleast point me in the right direction
  2. #2 Re: electrical issues
    Akron Ohio
    ignition switch
  3. #3 Re: electrical issues
    St. Louis Mo.
    There is the blower resister located behind the blower under the glove box. When that resister goes out, it can cause all kinda electrical problems. If your first 4 fan speeds are not working, it sounds like the resistor shot the big one.
    James Shafer
    St. Louis MO
  4. #4 Re: electrical issues
    let's toast til we die brand121's Avatar
    South Carolina
    but with the headlights going out too, the ignition switch...
    My couch pulls out, but, I don't...
  5. #5 Re: electrical issues
    Nov 2010
    canton, ohio
    I replaced the ignition switch and the regulator as well I'm starting to think maybe ground or the box under the driver side dash that dings when the key is in and the door is open because no matter what if the key is in or not it still bdings when the door is open
  6. #6 Re: electrical issues
    Nov 2009
    Grand haven
    Sounds like your ignition switch is bad still. Did you put a NEW one in or a USED one in?
  7. #7 Re: electrical issues
    ze font, is ze tres horrible.
    Oh and ignition switch + blower motor resistor.
  8. #8 Re: electrical issues
    Nov 2010
    canton, ohio
    i used a brand new ignition switch unless its body parts or something thats not vital i always buy brand new
  9. #9 Re: electrical issues
    Did you replace the blower motor resistor?
  10. #10 Re: electrical issues
    Nov 2010
    canton, ohio
    yes i did i replaced the resister ign. switch heater control headlight switch just about everything
  11. #11 Re: electrical issues
    New Brunswick
    Just to rule it out did you replace the actualy ignition switch or just the key cylinder?
  12. #12 Re: electrical issues
    Oct 2012
    philly
    I am having a similar issue with a 2003 GTP. when I turn the heat on the automatic lights go out and I have to turn the switch to get the lights on and the CID goes black. Anybody?
  1. Weird electrical/transmission/stall issues
    By Perry125 in forum General Tech Discussion
    Last Post: 09-19-2010, 10:16 AM
  2. Electrical Issues.
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 11:59 AM
  3. Electrical issues. alternator? battery?
    By Alex W in forum General Tech Discussion
    Last Post: 01-30-2010, 09:18 PM
  4. Minor electrical issues. any help?
    By NMillis in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 10:37 AM
  5. Lots of electrical issues
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-31-2008, 11:14 PM
