Thread: Wiring Wideband Gauge
Results 1 to 12 of 12
  1. #1 Wiring Wideband Gauge
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    What is the best way to wire the O2 sensor through the firewall? There isn't really a spot to fit that big of a cord.
  2. #2 Re: Wiring Wideband Gauge
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I ran mine thru the passanger side plug hole that near front seat
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Wiring Wideband Gauge
    Kansas
    Quote Originally Posted by 01gpgt01 View Post
    x2. I had a lil cut in it for power wire for the audio set up and the plug just pushed through.
    SOLD 1999 GT Silvermist TS
  4. #4 Re: Wiring Wideband Gauge
    Charles City, IA
    Thats what I did also.
    SMGPFC Two Nipple General
  5. #5 Re: Wiring Wideband Gauge
    there is a huge plug under the carpet on the passenger side where your feet go.
  6. #6 Re: Wiring Wideband Gauge
    Yea that's the one I was thinking of using, but my big amp power wire runs through there too, so hopefully I can get it to squeeze through. Thanks guys.
  7. #7 Re: Wiring Wideband Gauge
    Nov 2009
    Grand haven
    I ran mine through a gromet on the driverside by the steering wheel shaft.
  8. #8 Re: Wiring Wideband Gauge
    I ended up using the passenger side grommet. Just had to use a punch to make a big enough hole for the connector to fit through.
  9. #9 Re: Wiring Wideband Gauge
    i took the whole grommet out and then put everything through after i had it all run then smashed it back in the floor.
  10. #10 Re: Wiring Wideband Gauge
    Nov 2009
    Grand haven
    LOL you could have notched it a lil and then silconed it. MR SMASH GUY^^
  11. #11 Re: Wiring Wideband Gauge
  12. #12 Re: Wiring Wideband Gauge
    mine doesnt even fit in properly anymore... too many audio power cables.
  1. Wideband Gauge Question
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2010, 04:31 PM
