Thread: HID fuse
Results 1 to 7 of 7
04GTPTyler HID fuse 12-11-2010, 08:34 PM
TheOtherNick Re: HID fuse 12-11-2010, 08:35 PM
blueguy Re: HID fuse 12-11-2010, 08:36 PM
MizzBecca Re: HID fuse 12-11-2010, 08:37 PM
matt5112 Re: HID fuse 12-11-2010, 10:35 PM
03GTPLE Re: HID fuse 12-11-2010, 11:30 PM
csssaint12 Re: HID fuse 12-12-2010, 09:56 AM
  1. #1 HID fuse
    SE Level Member 04GTPTyler's Avatar
    Missouri
    My Fuse keeps blowing on my headlights ever since i installed my HIDS. Can i upgrade to a 20 fuse in a 04 GTP? Or is there another way to solve this problem?
    Thanks
  2. #2 Re: HID fuse
    Charles City, IA
    Use a relay harness.
    SMGPFC Two Nipple General
  3. #3 Re: HID fuse
    moved.
  4. #4 Re: HID fuse
    Becca Boo MizzBecca's Avatar
    Michigan
    ^such a good moderator.
    I drive a POS
  5. #5 Re: HID fuse
    NEVER PUT IN A BIGGER FUSE UNLESS YOU WANT YOUR CAR TO BURN DOWN.
    Your insurance company will also laugh at you if they find out.
  6. #6 Re: HID fuse
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    I think what I read is that the 04+ have reverse polarity, so that would explain the fuse popping. Contact the manufacturer, but they'll probably tell you to plug in the harness backwards.
    As stated before, do NOT put in a bigger fuse.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  7. #7 Re: HID fuse
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    the only possible way you could put in a bigger fuse is if you rewire the entire thing. Like stated above just use a wiring harness. If you are doing this then you can try to reverse the polarity like stated above and that should solve the problem. Reversing the polarity in my friends grand am was the trick for his vehicle.
  1. looking for fuse box for 97 GTP
    By hammerbuilt in forum General Tech Discussion
    Last Post: 07-28-2009, 03:31 PM
  2. need a fuse box 4 a 97 gtp
    By hammerbuilt in forum Introductions/Noob Questions
    Last Post: 07-25-2009, 06:25 PM
  3. Fuse Box
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 06:10 PM
  4. Big 3 fuse
    By c32k05 in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 02:06 PM
