Thread: Subs blown... amp fried? which one??
Results 1 to 20 of 37
  1. #1 Subs blown... amp fried? which one??
    Arizona
    so 2 days ago my subs stopped working, and i cant figure out if it is the subs or the amp that is busted
    i dont hear and feedback or weird noise from the subs when they are playing or just on.
    the led on the amp turns on, could it still be fried?
    could this be the subs and the amp?
    it looked like all the conncetions were good, i could be wrong though
    any ideas?
    '00 GT- nothing special
  2. #2 Re: Subs blown... amp fried? which one??
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    check rcas
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  3. #3 Re: Subs blown... amp fried? which one??
    GT Level Member AdamBall's Avatar
    Wausau, WI
    I say check your connections again and if so check your RCA's and possibly replace them they could be shot.
  4. #4 Re: Subs blown... amp fried? which one??
    swift current,sask.
    Check the resistance on the sub's with a multimeter, if they check out ok then you could look at your amp or rca's or even the deck.
  5. #5 Re: Subs blown... amp fried? which one??
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    like whiney said just put it on ohms and check to see what the resistance is.
  6. #6 Re: Subs blown... amp fried? which one??
    MO
    On your voltmeter (AC setting) hold it to the output from your amp and see if it spikes any with music playing.
    <brandonl2000> LMAO D!!
  7. #7 Re: Subs blown... amp fried? which one??
    Minnesota
    Is the amp on protect?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  8. #8 Re: Subs blown... amp fried? which one??
    Feb 2009
    Virginia
    Quote Originally Posted by whiney View Post
    Take it a step further. Plug an iPod into the AMP(bypassing your head unit) and see how it sounds.
    11 is louder than 10!
  9. #9 Re: Subs blown... amp fried? which one??
    Cedar Rapids, IA
    ipod throws alot of volts at it on full tilt so start at 1/4
  10. #10 Re: Subs blown... amp fried? which one??
    1.25 is a lot? : \
  11. #11 Re: Subs blown... amp fried? which one??
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    1.25 is a lot? : \
    1.25 what?
    ohms? volts?
    i just ahad a similar problem. take the subs out of the box and disconnect them and check with a multimeter on the ohms setting (as noted before) and it should be spec/ about 4 ohms depending on what subs you have
    i have 2 kenwoods that were supposed to be 4 ohm but i only got .5 ohm on one and 3.0 ohms on the other, i made the mistake of buying the subs used and assuming they were good...
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  12. #12 Re: Subs blown... amp fried? which one??
    Arizona
    is the multimeter the yellow thing?
    could someone get a pic and show me what to set it too?
    if its my deck, wouldnt none of the speakers work?
  13. #13 Re: Subs blown... amp fried? which one??
    Willoughby, Ohio
    ook what is your setup?
    easiest way is to put your amp in some1 elses car and see if it works
    i bet your subs are fine
    check output of amp with a mulitmeter if you dont wanna take it out
  14. #14 Re: Subs blown... amp fried? which one??
    swift current,sask.
    Quote Originally Posted by coreygnar View Post
    sure, it could be that color
    you will want to set it to volts ac, set it to like 200vac. Its not going to be any more than like 30 volts anyways
    could be just the sub output, or the wiring itself, that can also be ohm'd out too if you really feel like it.
    Subs blown... amp fried? which one?? Attached Images
  15. #15 Re: Subs blown... amp fried? which one??
    Nov 2009
    If u ohmed the subs an didn't get a number it mean that there is no a complete circuit and that is ur problem
  16. #16 Re: Subs blown... amp fried? which one??
    Arizona
    so we tested all the stuff i found the my rca's arent putting out anything really. so now im going to check on the head unit, and see whats going on in their....
  17. #17 Re: Subs blown... amp fried? which one??
    Feb 2009
    Virginia
    Typically...even if the head unit says "4V output" it's nowhere near that. Not because it's a "crappy" deck; but because music is DYNAMIC. Set gains and leave it be.
    RCA output voltage, nouseforaname
    EDIT: Go back and try what I said already...hook up an ipod or something to it and see if the sound is similar or dissimilar. Then you at least know if the problem is upstream or downstream.
  18. #18 Re: Subs blown... amp fried? which one??
    GT Level Member Deviq's Avatar
    SE WI
    Did your battery go dead or anything like that? If your stereo went to defaults make sure your sub outs are on if your stereo has that setting. Some stereos are set to off as a default.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  19. #19 Re: Subs blown... amp fried? which one??
    Arizona
    Quote Originally Posted by Deviq View Post
    i was driving when they stopped playing
  20. #20 Re: Subs blown... amp fried? which one??
    Feb 2009
    Virginia
    Corey...how did you have the DMM setup when you were measuring? First...what's your DMM able to handle; 40hz thru 400hz? Play a test tone at one of those frequencies and measure AC voltage. If you were measuring during music then it's dynamic and wouldn't be that great.
    However, setting gain with 0 decibel sine wave probably isn't a good way to handle the situation. So don't use the DMM to set your gains. Output from your amp will be pretty low on most music if you do so.
    Did you try the ipod idea yet?
  1. I fried my pcm today
    By 99prixgt in forum General Tech Discussion
    Last Post: 07-03-2010, 07:24 PM
  2. Blown 3.8
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 03:59 PM
  3. blown subs
    By 02gtpsleeper in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 11:44 AM
  4. fried/bricked pcms?
    By glanzergtx in forum PCM Tuning
    Last Post: 10-02-2009, 04:24 PM
  5. Anyone ever watch Country Fried Home Videos?
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 01-14-2008, 03:12 PM
