Thread: Pontiac grand prix gt drivers information center dic
Results 1 to 20 of 20
  1. #1 Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    Is there any way that i can up-grade the DRIVERS INFORMATION CENTER DIC from the one that shows the pic of a car and shows when doors are open? to the one that come with the screen in the gtp?? let me know thanks
  2. #2 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    any info????
  3. #3 Re: Pontiac grand prix gt drivers information center dic
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    http://www.grandprixforums.net/f73/a...03-a-8171.html
    that should help and its a yes i plan to do mine at some point
  4. #4 Re: Pontiac grand prix gt drivers information center dic
    GTP Level Member SuperSport's Avatar
    Michigan
    I did the swap. It takes a good 3 hours of splicing 20 or so wires, but in the end its well worth it.
    Make sure you get the digital DIC with the TRAC button, not the TCS button.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  5. #5 Re: Pontiac grand prix gt drivers information center dic
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Did the GT models ever have the digital DIC? I assume the TCS button is on the GTP models. I thought only the analog DIC had the Trac button but I must be wrong.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  6. #6 Re: Pontiac grand prix gt drivers information center dic
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    Quote Originally Posted by nault31 View Post
    my GT has it from the factory.
    New project: 2000 Red GTP.
  7. #7 Re: Pontiac grand prix gt drivers information center dic
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Yes, it was an option on the GT, however unlike stated above you CAN use a GTP DIC, you just have to open it up and cut one of the soldering points.
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  8. #8 Re: Pontiac grand prix gt drivers information center dic
    Thanks, yes I finally saw a digital one with the trac button on ebay and the club gp how to on soldering a wire to fix the tcs button if I bought a gtp dic.
    Can I assume my 98 GT would have all of the wiring for the mpg and other data to work or would I have to add a few wires?
  9. #9 Re: Pontiac grand prix gt drivers information center dic
    Nov 2008
    Yeah, just have to splice a couple wires in the harness
  10. #10 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    any pic's
  11. #11 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    thanks for the info
  12. #12 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    Can i used a DIC from a 97 GT?? i found 3 in a local yunkyard thats the only one's i can find let me know thanks
  13. #13 Re: Pontiac grand prix gt drivers information center dic
    Dec 2008
    Lawndale, CA
    97 can only be used in a 97. It's a special case for the 97's. You need one from a 99-03.
    I used this thread.
    ClubGP Message Forum troubleshooting
  14. #14 Re: Pontiac grand prix gt drivers information center dic
    You'll want to look for a 98-03 GT with a DIC where the button says TRAC not TCS. The 97 has a tire pressure monitor light and is incompatible. I was lucky to find one cheap on ebay and the connector was already wrapped in the dash so no splicing.
  15. #15 Re: Pontiac grand prix gt drivers information center dic
    Racine, WI
    98-02 DIC are all interchangeable.
    If you have a <99 GP, the harness for the digitial DIC is already there and this is a plug and play mod.
  16. #16 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    Quote Originally Posted by BlitzGT View Post
    ok.
  17. #17 Re: Pontiac grand prix gt drivers information center dic
    Feb 2009
    BrownsTown, MI
    i got 99 gt it would be plug and play?
  18. #18 Re: Pontiac grand prix gt drivers information center dic
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by 99GTP99 View Post
    You have to pop the dash off to see if the connector is there. It's hit or miss. My 99 did not have the connector.
  19. #19 Re: Pontiac grand prix gt drivers information center dic
    what if I want too put a 97 GTP>>>>d.i.c into a GT?
  20. #20 Re: Pontiac grand prix gt drivers information center dic
    Jersey
    my dic on my 97 gt has a trac light and its for sale
    check my f/s thread
    16' wrx sti- stock
  1. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  2. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
