Thread: H.I.D Issues...need help?
Results 1 to 20 of 21
  1. #1 H.I.D Issues...need help?
    Jun 2010
    Portage, Mi
    I purchased a HID set up and installed it. while I hooked everything up I noticed a flicker on the driver side...so I looked online and I read that I needed a flicker relay maybe? I dont know what that is but if anybody can help that would be awesome!!! Thanks guys....
  2. #2 Re: H.I.D Issues...need help?
    West Side Michigan
    I've never heard of a flicker relay..
    Get yourself a RELAY Harness. It's only $10 online and will fix your HID problems. This is of course.. granted it's not a terrible quality kit.
  3. #3 Re: H.I.D Issues...need help?
    Jun 2010
    Portage, Mi
    Quote Originally Posted by nawarkk View Post
    A relay harness? Is there a certain one I have to get or are they universal?
  4. #4 Re: H.I.D Issues...need help?
    West Side Michigan
    They are pretty much all universal. I'm pretty sure you need to get the one that works with your bulb.. So if you're using a 9007 bulb you need a 9007 relay harness etc etc.
  5. #5 Re: H.I.D Issues...need help?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    like nawarkk said get a relay harness so the power that the bulb is drawing is coming from the battery and not through the factory wiring cause if you do some research on the ballists you would find that they take some crazy huge voltage to start up sometimes. and i bet the flickering only happens during the day when the drls are on
  6. #6 Re: H.I.D Issues...need help?
    Jun 2010
    Portage, Mi
    Quote Originally Posted by csssaint12 View Post
    I guess I could have researched it but considering that my friend got a set for his VW Passat and had no issues, and they are suppose to be plug and play pretty much didnt warrant me to look. This my first time putting these on any of the cars I own. I guess I know now!!! And for that matter the place where I got them should have said you will need to purchase a 9007 Relay Harness. Oh well you live and learn right? (I ordered the harness)
  7. #7 Re: H.I.D Issues...need help?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    I wanna go full HIDs. ( just installed low beams today ). I got the relay harness...anybody got a write-up on installing the relay harness? or already done so? looks like your pretty much re-wiring your car.....
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  8. #8 Re: H.I.D Issues...need help?
    Florida
    Relay harnesses arent hard to install, Ground the ground, hook the positive to the positive battery terminal, splice the signal wire, and attach to the bulb sockets.
    Oddly enough, when I put my HID Lowbeams in my projectors, they werent worth ****, took the harness out, and bam, work perfectly.
    Just some food for thought
  9. #9 Re: H.I.D Issues...need help?
    Aug 2008
    Fayetteville, NC
    wait so ur HID's worked better with a re-wired harness?
    I just installed my lows today and I already notice, my 6k's are no brighter than my silvania ultras :\ ... kinda disappointing but the cool blue color is great.
  10. #10 Re: H.I.D Issues...need help?
    Florida
    Yeah, mine worked way better without the relay harness.
    Theres a problem if your HIDs are as bright as halogens, they should be MUCH brighter. *mine are also 6k*
  11. #11 Re: H.I.D Issues...need help?
    You could make your own, $5 for a relay + cost of connectors and time.
    But you'd need to perma-mod your stock wiring harness.
  12. #12 Re: H.I.D Issues...need help?
    Aug 2008
    Fayetteville, NC
    don't tell me that...
  13. #13 Re: H.I.D Issues...need help?
    Florida
    well, I had Silverstars in mine for lowbeams, and they were okay, brightness was about a 3 (1-10).
    Put the HIDs in and they are now about 12 (1-10)
    They are extremely bright. All I can say is, make sure you dont have a weak ground or power connection.
  14. #14 Re: H.I.D Issues...need help?
    Aug 2008
    Fayetteville, NC
    ah well I just got done installing my harness's about an hour ago, its almost dark. I guess we will see...
  15. #15 Re: H.I.D Issues...need help?
    Florida
    Drum roll.............
    /fingers crossed
  16. #16 Re: H.I.D Issues...need help?
    Aug 2008
    Fayetteville, NC
    well they are a TAD bit brighter with the HID harness's but still look like the following...I'm not that impressed...
    I tried to get a better night pic of the road but this one is actually the best :\ seems alot brighter than this in person though...
  17. #17 Re: H.I.D Issues...need help?
    Florida
    hrm...are you headlights hazed any? Because my 6ks make everything extremely bright. For example, the yellow divider line on roads almost appears almost white/cream colored.
  18. #18 Re: H.I.D Issues...need help?
    Aug 2008
    Fayetteville, NC
    yes, I have slight oxidation, but I think my trouble lies beyond oxidation. and there was no divider on that particular road, traffic was bad tonight so I had to pick a real-boonie road, sorry I didn't get that but I got the stop sign.
    but do you guys see why I'm not that impressed?
  19. #19 Re: H.I.D Issues...need help?
    pennsylvania
    i have same issue with my hids so i bought a brand new kit and still flickering. So i got relay harnass still flickering do you think it has something to do with my daytime lights?
  20. #20 Re: H.I.D Issues...need help?
    Got any idea what the voltage is at? Looks like you have a voltage or ground problem or both...........
    Miltimeter is your friend go check the alt.
  1. tcs issues still
    By LAIDBACKLUKE in forum General Tech Discussion
    Last Post: 05-11-2010, 01:54 AM
  2. 05 pcm issues in 07
    By vailskier3 in forum PCM Tuning
    Last Post: 03-07-2010, 06:34 PM
  3. DLP tv issues
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 01-20-2010, 01:19 PM
  4. A few issues
    By Ellen in forum General Tech Discussion
    Last Post: 09-17-2009, 09:29 AM
  5. HID issues
    By 99prixgt in forum General Tech Discussion
    Last Post: 12-25-2008, 12:27 PM
