Thread: fitting into trunk 1997 grand prix se
Results 1 to 8 of 8
  1. #1 fitting into trunk 1997 grand prix se
    michigan
    i have 2 15inch kicker l7 coming and i need to build a box for them. i want it like 36" wide 17" tall and depth is the problem i have you cant go very deep or it wont fit. is there a trick to fitting a deep box in there? my back seats dont fold down. or is it possible to build the box inside of the trunk? oh i have a 1997 grand prix se.
  2. #2 Re: fitting into trunk 1997 grand prix se
    Feb 2009
    Virginia
    Personally...that's over-kill. However, to each their own I would suggest building it inside the actual trunk. But I would also be modeling this using WinISD or similar programs. Do you know exactly what you want or are looking for from these speakers? I suggest finding the t/s parameters first.
    11 is louder than 10!
  3. #3 Re: fitting into trunk 1997 grand prix se
    Jan 2009
    Tabor SD
    I used a sealed box for 2 L7's in a friends GP that was 36 wide 15.5 high and 18 deep it gives about 2.25 ft3 per chamber
  4. #4 Re: fitting into trunk 1997 grand prix se
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    as i stated in one of your other 3 threads too big just do 1 and call it good... eather way mine will be louder haha
    and if your going to build to spec it will have to be built in trunk like mine was
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  5. #5 Re: fitting into trunk 1997 grand prix se
    Jan 2009
    Tabor SD
    Quote Originally Posted by TurboTrav View Post
    Do you like the AQ sdc 2.5? Ive heard alot of good things about them. The reason I asked is because my nephew has some that I'm going to put in a forward firing Sixth order bandpass and seal it to his pass threw. He just got them and I installed them into a pre-fab sealed box and they sound like sh*t. His plan was to break them in then let me build the new box.
  6. #6 Re: fitting into trunk 1997 grand prix se
    Cedar Rapids, IA
    pass through on a 97-03? or 04+
    my box is built to spec and yes i love them great response.
    did 138.6 on the center of the dash on music over a 3 min time UNDER power getting 1800 to them max they will take 2k if its clean
  7. #7 Re: fitting into trunk 1997 grand prix se
    Jan 2009
    Tabor SD
    [QUOTE=TurboTrav;420235]pass through on a 97-03? or 04+
    did 138.6 on the center of the dash on music over a 3 min time UNDER power getting 1800 to them max they will take 2k if its clean[/QUOTE
    Its for a 97 GP. It was designed for the subs and the cabin or loading environment. I also have a Fourth order design for those subs but its a forward facing box with the ports on the outer edges not in the center like the sixth order bandpass. Both boxes are designed to get maximum excursion on 1200 to 1400 watts and are tuned to 35Hz. That is what DJ from audioque told me to tune them at for the best response. He also said they should handle a AQ2200d in short burst but the guy that designed these enclosures said no way. They would exceed the sub suspensions limits and either bottom out or get some magic smoke rolling.
  8. #8 Re: fitting into trunk 1997 grand prix se
    Cedar Rapids, IA
    i've put 2500w to them with no problems
    tuned to 38 tho
  1. 1997 Pontiac Grand Prix GT
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 12-27-2009, 07:31 PM
  2. 1997 Pontiac Grand prix SE
    By bizzy187 in forum Visual/Body Modifications
    Last Post: 05-14-2008, 11:25 AM
  3. Fitting a double din reciever into 00 grand prix
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 01-26-2008, 11:57 AM
