Thread: Not getting any power to my head unit???
Results 1 to 4 of 4
  1. #1 Not getting any power to my head unit???
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Don't know why but i reinstalled my double din after 3 months of it sitting in the shop without it and i turn on the car but the head unit doesn't turn on. I check the head unit fuse and its good and also the radio fuse in the car and its also good. But when i used a tester on the cars radio fuse...it doesn't light up meaning its not getting any power to that fuse at all. Why is this?
    Could the retained accessory power relay be the problem?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Not getting any power to my head unit???
    could be.
    have you taken a DMM to the constant positive on the radio's harness.
    Then try the switched and see if you get anything when turning the ignition to on or accessory.
  3. #3 Re: Not getting any power to my head unit???
    SE Level Member mriley's Avatar
    Jun 2010
    enfield ct
    check your power wire and ground for starters. also check if you have any exposed wires touching eachother
  4. #4 Re: Not getting any power to my head unit???
    SE Level Member ChicagoGXP's Avatar
    Chicago
    Maybe your "lambo" doors are creating a short....
    <facepalm>
  1. What should/can I do about my head unit?
    By TruckToPrix in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2010, 09:44 PM
  2. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  3. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
