Thread: Monsoon crackle noise
Results 1 to 5 of 5
  1. #1 Monsoon crackle noise
    Jan 2012
    Westland, Mi
    My 2007 Grandprix's Monsoon right rear deck speaker makes a continuous crackle noise when I hit a bump or close the trunk. If I disconnect the speaker it stops then starts again when I reconnect it. When I disconnect the monsoon it stops. When I reconnect the Monsoon it stays stopped until I hit a bump or close the trunk. Any solutions... Thanks
  2. #2 Re: Monsoon crackle noise
    moved. please watch where you are posting.
    i know you werent since this was posted in the first section you found on the page.
  3. #3 Re: Monsoon crackle noise
    Jan 2012
    Westland, Mi
    Sorry about that, I am a "Brand New" member..... Thank you for pointing out my error in such a non- judgmental way Mr. Site police........
  4. #4 Re: Monsoon crackle noise
    Apr 2011
    Athens, AL
    If it is a crackle that occurs from being jarred around, it is obviously a bad connection somewhere around the speaker or somewhere in the wiring. It is intermittent because sometimes the connection is made fine and other times not.The trick is finding out exactly where the problem is at. It could be at the solder point on the speaker, in the speaker connector (assuming it is a factory speaker), or a break in the wiring somewhere. The best way to determine the problem is to lay in the trunk with the radio on and move the wiring and try to zero in on the problem area.
  5. #5 Re: Monsoon crackle noise
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    a crackle in a speaker is not normal. even if you are giving it power and taking it away. replace the speaker.
  1. I have a Monsoon Q on my 05 GTP
    By JJL7584 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 05:28 PM
  2. 06 gt monsoon
    By JAMIEPERRY86 in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2011, 07:55 PM
  3. 07 monsoon help...
    By wide open 97 in forum Audio, Security & Visual Electronics
    Last Post: 01-01-2011, 10:02 PM
  4. Monsoon?
    By Berger in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2008, 11:29 AM
