you can see and read stuff as long as it's a light shade being that the dome lights are green, anything that is dark can't be read because of the laws of optics lol
i like it. how tough is it to change over the PRND321 lights? i'd like to have everything green in the future
I just feel like I got abducted
holy green, i actually did the same thing in my first car, in red, in all the same exact places, when i was SIXTEEN good times
its all good man, we all have phases. i grew outta my system phase that i never thought i would grow out of, i guess 4000 watts for 16 months just burned me out ha
I think it looks hot. And you dont even have to grow out of it. I had a color changing LED set on my car when i was 18, 7 years and several tickets later, I still have LED lights but they are street legal (see sig)
where are you that they give tickets for neons or LEDs? as long as they are hidden and you cant see the bulb they are legal in ohio
grew outta mine at 19 too, and btw notladstyle, are those turn signal arrows on the exhaust tips????
oh ya as long as the red or blue isnt flashing you wont get pulled over in ohio, and idk about the raised wing in that pic...
i've never seen a raised spoiler before. it's interesting lol. kinda like it, kinda don't. but i'll give props for originality
edit: wait, ctk, you're in pitt OH?
I raised it because dirt was getting underneath it and would wash out and leave brown streaks. The only screws I could find that fit were 2" long and I didn't have time to dremel them down until about 6 months later.
I did dremel them to 3/4" and it looks a lot better but still leaves room for the LED strip which I have since hooked to the brake lights.
definitely use 3 or 4, never did it because I want to do backinblack's drive shift mod down there at some point.The sifter on the center counsel has 1 bulb in it, i do believe its a 194 or 168 bulb, either works. You have to take the center counsel apart to get at it and then you have to scrap the red film from inside the plastic piece to get it to show up decently. I only used 1 green led but i suggest at least 3, mines too dim.
use a larger bulb or a LED strip run in parallel with the back plate for the LEDs,
Here is his original project, I wanted to rewire it to work with the lower shifter and the cluster display. unfortunately I never have time to work on electronics projects any more.
http://www.backinblackgp.com/SVRS.htm
its going to be gross. It took 20 minutes to get the area clean under it, also where the seal between the spoiler and the trunk mate will probably need some wax and care.
