Thread: Amp or no Amp
Results 1 to 8 of 8
2000GTGP Amp or no Amp 06-07-2010, 09:59 PM
whiney Re: Amp or no Amp 06-07-2010, 10:03 PM
2000GTGP Re: Amp or no Amp 06-07-2010, 10:07 PM
whiney Re: Amp or no Amp 06-07-2010, 10:12 PM
2000GTGP Re: Amp or no Amp 06-07-2010, 10:19 PM
whiney Re: Amp or no Amp 06-07-2010, 10:23 PM
2000GTGP Re: Amp or no Amp 06-07-2010, 10:27 PM
matt5112 Re: Amp or no Amp 06-08-2010, 07:17 PM
  1. #1 Amp or no Amp
    Nov 2009
    illinois
    alright i got a friend selling an amp at a good price. Currently i have no amp to my door speakers so bass from my sub kind of over powers them. I am just wondering if i hook this amp up would my speakers take the extra power. I know the rear will but im not so sure about my fronts.
    Front Speakers: Memphis 15-PR52 (15pr52) - 5-1/4" Speakers - Sonic Electronix
    Rear Speakers: Memphis 15-PR692 (15pr692) - 6" x 9" Speakers - Sonic Electronix
    Amp i would be getting Zx640: Kicker ZX460-2 (zx460) - Discontinued Car Audio & Video - Sonic Electronix
    it would be wired at 4 ohm giving 30 rms according to specs. Ive looked around and many have stated its actually ~50rms watts it puts out at 4 ohms. That would be perfect for my rear but would that fry my fronts? Would it sound bad if i just amped my rear speakers?
    Also these speakers like to make the shrill "s" sound at times. if i amp that is it going to make it a lot worse. I can live with it if i does my main concern at the moment is can i run this amp to my fronts without frying them?
    Thanks in advance
  2. #2 Re: Amp or no Amp
    swift current,sask.
    Just run the amp, you won't regret it either way. You will have a whole lot better quality from them. If the are set up right you shouldnt have to worry about giving them 30 watts.
  3. #3 Re: Amp or no Amp
    Nov 2009
    illinois
    30 rms would be great to the front but like i said after researching a bit people have stated it puts out around 50rms which is a little more than i need.
  4. #4 Re: Amp or no Amp
    swift current,sask.
    50 will be fine I think, set your gains down a bit. I'm running like 200 watts to my type r's in the front and the rms on them is like 110.
  5. #5 Re: Amp or no Amp
    Nov 2009
    illinois
    alright. the amp does have an amp 1 amp 2 setup with separate gains on each. put fronts on amp 1 back on amp 2 and turn gain down on amp 1. With running different power to front and back is that going to sound bad or should i adjust the gains on both to match? also will the shrill "sss" sound get worse?
    sorry for all the questions still kinda new to all this audio stuff.
  6. #6 Re: Amp or no Amp
    swift current,sask.
    adjust it to your liking, i'm not following you on the "sss" sound though?
  7. #7 Re: Amp or no Amp
    Nov 2009
    illinois
    their shrill/over exaggerated. you know what im talking about if you have heard it before. ill wait for someone else to chime in on it.
  8. #8 Re: Amp or no Amp
    the difference is maybe 2 dB. I dont think you'll notice.
    Between 30 and 50 W that is.
    But more is better.
amp
