Thread: which harness for bose
Results 1 to 5 of 5
  1. #1 which harness for bose
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    so i got a cheap aftermarket headunit. the stock one took a poop. it came with free shipping, the wire harness and installation bullsh*t. so more power to me, nothing wrong with free.
    anyways im planning on doing the 70-1858 harness, because its cheap. i read thru this (http://www.grandprixforums.net/radio_install_info.php) a handful of times and im still confused. i NEED the harness to work with the bose right? or can i just use the harness that came with the headunit? and is it plug and play?
    thanks
  2. #2 Re: which harness for bose
    Oct 2008
    Peoria, IL
    tttttttttttttttttttttttttttttttttt
  3. #3 Re: which harness for bose
    There is no bumping in the audio section unless you're in your car....
    plug in the harness they give you, connect pink wire from bose harness and magic will happen
  4. #4 Re: which harness for bose
    swift current,sask.
    ^^What he said, just rip it out of the harness or cut it and hook it up to the remote wire on your deck. And you will have tunes again.
  5. #5 Re: which harness for bose
    Oct 2008
    Peoria, IL
    good deal, gracias
  1. Does Bose Work with Non-Bose cars?
    By grandprix17 in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2010, 08:07 AM
  2. Bose amp wattage
    By bm127 in forum Introductions/Noob Questions
    Last Post: 10-25-2009, 09:11 PM
  3. Bose
    By BwolfGT in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 07:33 AM
  4. Bose
    By trenaro in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2009, 10:02 PM
  5. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
