mine have been off many times, still doing just fine.
more accurately describe what parts you're talking about so we can better answer.
basically, the window came out of the track. the track being the two plastic clips that the window got glued to from the factory and are the parts that physically pull it down. i was hoping to find something at a store, but i might see if a gm dealer has something.
epoxy or get new clips from GM.
all the speakers came to today, but the 4's dont fit in the stock mount. what should I do?
also where can i get those little plastic holding trees or whatever they are called, i can tell i will need them later
and for wiring, im gonna need some help
How does it not fit? Describe the fit issue.
You can get those xmas trees at your local parts store.
As for wiring, its positive to positive and negative to negative.
basket is too big too fast, cut out some plastic or metal so it fits.
dremel, hacksaw, reciprocating saw, i dunno what ever turns your crank. No seriously i would use a dremel.
did you have fun getting the door panel back on? i always manage to forget to put the handle back through. never fails.
i'll hold you too that, i think i'm up to five on the passenger door lol. and because of not replacing the clips each time, i get i can have the panel off faster than i can go 0-60mph haha
getting the panel back on is cake
i need new xmas trees, also i have to pull it off again so i can get the torx bolts that fell when i tried screwing them in
