With low power sensitivity is the key ingredient for efficiency.
Look for 90db/1watt or higher.
i dont know what that means, please explain.
would these work?
Amazon.com: Kicker 4 Inch Two Way Car Speakers Pair Pric - 07DS400: Automotive
Amazon.com: Kicker 07DS5250 525-Inch 130mm Coax Speakers (Pair): Electronics
anyone? please i need to order those soon if they are right
The one thing he told you to look for isnt mentioned there....
They'd be good. try 'em.
4's for what? I thought you said the rear 6x9's were gone?
found out it was a 4 inch back there
these 4 inchers
oh true, you sure its the 4 not the 6x9 thats gone?
those are pretty good for 4's.
well for both sets it cost 90 bucks, so im not expecting anything amazing, just an upgrade from my old ones
should do the job quite well then. let us know how they are when you get 'em.
Do you know how to get at the rear speakers?
Good old gm and their bright ideas...
Tell me about it.... :D
two torx bolts behind those plastic plugs behind the handles then it pulls off, similar to the dash. the rest is self explanatory.
i'm gonna recommend some replacement pins from autozone or something. they don't like being pulled out. especially the second time, f*cking window.
sidebar: still need a recommendation on a really good adhesive to get my window to stick to the clips it came out of.
/threadjack
