Thread: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 89
  1. #21 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    What all did you order? Just the single HID kit for your headlamp, the 9007 for the factory lamp? Did you get the (hi/low) option? I am curious because this is what i was thinking about doing soon. Let me know what you think.
    Quote Originally Posted by JoRoW99 View Post
    ok, a full 2 weeks later i finally received them in the mail. it was pretty confusing, and there was a point where i was just yelling "what the F*&%!" its mostly because where the old bulb connects to the new harness, they dont have it plugged in. like they just give you 2 wires and a connector thing so i just had to guess to figure it out. i havent really tried them out at night yet because its not dark, but ill post later.
  2. #22 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Grand Island, Nebraska
    I got this
    Apexcone Raptor HID Kit (35w or 55w): HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
    35w (i heard 55w will melt things)
    9007 (not hi/lo)
    8000K (not sure if this is the actual color it got, its not very blue. im thinking i got 6000k but they are still sweet)
    the hi/lo i think is just that there is a halogen high beam, but dont quote me on that. right now, i dont have high beams, when i switch to high beams, they just turn off.
    i also ordered a relay harness off ebay from zzp
    HID Fuse Relay Wire Wiring Harness 9005 9006 9007 H1 : eBay Motors (item 170343636647 end time May-07-10 19:22:48 PDT)
    the relay basically supplies the power straight from the battery, so you get constant power and you dont risk melting the stock wiring. plus its only $10, so why wouldnt you get them? some people run them fine without a harness though. if you decide to get these, hit me up with a pm and id help you try to figure out how to wire them up, since the instructions they come with dont tell you crap.
  3. #23 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    mine are still "processing"... ordered last week...
    you would have had to add the hi/lo option ($20 more) when your ordered it to get both hi/lo HIDs.
    I got
    35w
    9007 Hi/Lo
    5000K (didn't want blue)
    I thought the online instructions were pretty good. It shows/states how one side will be unplugged.
    try the hi/low instructions
    https://www.ddmtuning.com/support/in...emid=1&nav=0,1
    just low instructions
    https://www.ddmtuning.com/support/in...emid=3&nav=0,1
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  4. #24 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Yeah good choice with the 35w. Like how they turned out? Significantly brighter? I am wondering if the (hi/low) option is worth it, they said on there sight that the option is just simply something that slides the bulb forwards and backwards to aim the light differently, not sure how i feel about that. Let me know what you think of that relay harness, im also wondering if you can hook up multiple HID's ( I was thinking fogs) to the same harness...
    I got this
    9007 (not hi/lo)
  5. #25 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    you would need another harness im pretty sure. mine are at least 3 times brighter, and i didnt even get the brightest color (brightest is 4300K i think.)
  6. #26 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Denver Colorado
    Quote Originally Posted by vailskier3 View Post
    i think a lot of people go with Xenon light Hid kit Hid light Hid headlights Bulbs Ballasts Car parts 's HID kits. i just got a cheap $50 ebay set and a $10 harness and i was good to go...i will never have a car without HID's ever again. NEVER (unless they make something better ).
    I'm with you bro. I feel tha same way. It's time for everyone to go to HID. It's just that much better for everyone behind the steering wheel going in BOTH directions.
  7. #27 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Denver Colorado
    Quote Originally Posted by chamilton89 View Post
    Hey guys, I am new to this forum and am looking into some halo projectors. I also want to look into ordering some HID's but most of them I have found that people recommend are over 100 bucks and only include low beams. Are they worth it? Are just low beams good enough? Does anyone know of some HIGH QUALITY brands that are more reasonably priced? Thanks!
    I would say to stay in the lower Kelvin numbers. I found 6000K is great with a hint of blue and 5000K with mostly white but are about as bright as you can get and stay to the blue side of the spectrum. I use 5000K in my fog lights. You will find a slight delay because of the igniter when you switch to high beams, but I drive long stretches with high beams on. Again 6000K is just right. At least for me. One of the best upgrades you can do to your car...period. Worth it? You bet. Most of the bulbs are made by Sylvania and marketed via China under other labels. Where you can get boned is in the ballast. PM me and I will give you the address to buy direct from China. They get here in 7-10 days! and you beat all the BS. These are the ones that everyone buys and puts in other packaging. Top of the line. 30 minute install in most cases.
  8. #28 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Denver Colorado
    If your lights look nice and steady, SAVE YOUR MONEY and time.
    The reason for the harness is NOT because of added current draw. HID systems use less than half the power of Halogen. The reason is that many automobiles (mostly large trucks with high capacity alternators or poor voltage regulators in many imports) don't provide a nice constant regulated 13.8 volts through the wiring harness. The idea of going directly to the battery is to get a much more constant voltage so your lights won't "flicker".
    Other than a "flicker", there's no reason to bother. You could run HID for three cars on the wires you have now.
  9. #29 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    I got this
    9007 (not hi/lo)
    did you get that harness installed? I have basically the same one from DDM tuning and have no idea where to start...but it looks the same, even came with a fuse...get back with me...thnx
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  10. #30 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Tyler, TX
    I found instructions on the DDM website. look at post #23 for the links... (just a couple up)
  11. #31 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Aug 2008
    Fayetteville, NC
    ill take a look, thnx
  12. #32 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    Idk that much about hids in GPs, but I can say plenty about them in Cobalts. Are they worth it? Absolutely. They look 10x better, and allow you to see the road like never before.
    2006 Mitsubishi Evo IX MR
  13. #33 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Aug 2008
    Fayetteville, NC
    I think I might need to install my HID harness because my HID's from DDM are just as bright as my sylvania ultras...Only thing differn't seems to be the color :\
  14. #34 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Poland, Ohio
    adding a relay harness wont make the bulbs brighter, just take the stress off your stock wiring and make them safer. It could be that the positioning of the bulb in the reflector housing is off with the elongated shape of hid bulbs and causing the light to improperly scatter, thus not shining on the road as much.
  15. #35 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Tommyp2010 View Post
    nah, I think position is fine...doesn't seem to be blinding drivings and is pretty much same output as slyvania's lol...only differnce I can tell is color lol but w/e 6K's are pretty
  16. #36 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Check the distance between the centre of the filament and the base plate where it mates with the headlight housing.
    If that distance doesnt match that of your halogen bulbs then thats your issue.... I had to trim mine, really increased the light output.
  17. #37 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Aug 2008
    Fayetteville, NC
    and whats a filament?
  18. #38 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    I was thinking about getting HID's through DDM because they are so cheap. Do you guys think it is worth it to get HID's for both the headlights and the fogs? If so should I get a harness for both sets? Also, DDM, says something about a hi/low option. Anyone ever used these particular bulbs? When installing, do I have to remove the DRL's fuse or can i keep the fuse in?
  19. #39 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    Poland, Ohio
    You might as well get hids for both the headlights and the fogs, if nothing else purely for matching purposes. You will need a seperate relay harness for your headlights and fog lights, along with seperate ballasts. It's a good idea to remove your DRL fuse because the DRLs run on "half" power, which play havoc with hids, weather or not you are using a relay harness.
  20. #40 Re: HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    SE Level Member d8teen's Avatar
    Jul 2010
    Fl-Hollywood
    I also have bmw with factory HID, this the best way to have hid's done. If you buy it aftermarket they have to be not cheapo.
  1. Anyone think this looks good??
    By hester21289 in forum Audio, Security & Visual Electronics
    Last Post: 09-22-2010, 12:52 AM
  2. Is this kit any good?
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2010, 08:00 PM
  3. hid by max car any good?
    By raymondtrudeau in forum Visual/Body Modifications
    Last Post: 10-16-2009, 10:41 AM
  4. is this any good?
    By Nickell in forum Off Topic Discussion
    Last Post: 10-12-2009, 06:10 AM
  5. Good day!
    By bat119 in forum Introductions/Noob Questions
    Last Post: 03-06-2008, 07:36 PM
