Thread: D.I.C flashing issue
Results 1 to 12 of 12
  1. #1 D.I.C flashing issue
    Jan 2009
    pennylvania
    Alright so a few weeks ago my D.I.C started blinking 0 for everything while i was driving. a few minutes later it reset and went back to normal and since then it keeps doing it. it will be fine the go to 0 then be fine for a few minutes then do it again. i also noticed that when it goes to 0 the digital heating display flashes. does anyone know what this might be? i dont have a clue
    2000 silvermist gtp- cai, res delete, 3.4" setup soon
  2. #2 Re: D.I.C flashing issue
    Wichita
    Either you have a junk PCM or a bad ground to your motor.
  3. #3 Re: D.I.C flashing issue
    Yeah had this happen to me... Junk PCM
  4. #4 Re: D.I.C flashing issue
    Wichita
    It happened to me as well. I had a bad engine ground. Check your ground before jumping to buy a new PCM.
  5. #5 Re: D.I.C flashing issue
    Jan 2009
    pennylvania
    the pcm is stock could it just go bad like that?
  6. #6 Re: D.I.C flashing issue
    Had a mail-order tune and it did it, swapped back to stock PCM and it was fine.
  7. #7 Re: D.I.C flashing issue
    yes but check for gounding issues first, stock grounds are pretty ****ty.
  8. #8 Re: D.I.C flashing issue
    Jan 2009
    pennylvania
    not to sound dumb but where are these located at haha im kinda new to this
  9. #9 Re: D.I.C flashing issue
    Jan 2009
    pennylvania
    just to clarify imtalking about the grounds not the pcm
  10. #10 Re: D.I.C flashing issue
    Wichita
    There's is a ground on one of the bolts connecting the motor & tranny, idk were the others are. Good way to check for this without having to look is to have the car tested for OHMs, if your car has too much resistance you more than likely have a bad ground.
  11. #11 Re: D.I.C flashing issue
    Jan 2009
    pennylvania
    thanks guys ill check the grounds tomorrow. Since my pcm may be junk and i was planning on getting a new one anyway is there any suggestions toward which one i should get. i was leaning toward overkill
  12. #12 Re: D.I.C flashing issue
    i'd actually suggest overkill, just try to get in contact first before ordering to make sure you'd get it on a somewhat timely basis.
  1. Flashing SES?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-04-2010, 02:57 PM
  2. DIC flashing zero
    By matt5112 in forum General Tech Discussion
    Last Post: 12-07-2009, 01:39 PM
  3. Troubleshooting: DIC Resetting/Flashing
    By Lawngoose in forum General Tech Discussion
    Last Post: 04-30-2009, 12:27 PM
  4. Flashing the PCM
    By Freebeer187 in forum General Tech Discussion
    Last Post: 07-22-2008, 10:47 PM
  5. display flashing
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2008, 04:43 PM
