Thread: Factory Amp in '97 GP Coupe
Results 1 to 4 of 4
  1. #1 Factory Amp in '97 GP Coupe
    Feb 2010
    Pittsburgh
    I've got a '97 GT coupe w/ all the fixins and just replaced the factory speakers (8 total) with BAs because they were blown. Once I got everything wrapped-up, I found that the 6x9s were not working in the rear deck. Put the old back in and no dice. I'm guessing the factory Delco Amp has gone bad. Has anyone else had this happen? I'd like to keep it simple and cheap and only replace the factory stuff (amp & wires if I have to) instead of buying after-market. Are the Delco amps still avail?
  2. #2 Re: Factory Amp in '97 GP Coupe
    Willoughby, Ohio
    check your wiring again just to make sure. dont wanna spend money you dont have to
  3. #3 Re: Factory Amp in '97 GP Coupe
    Feb 2010
    Pittsburgh
    Ok, thanks. I hate to sound stupid, but how do I check the wiring? Sounds laborous. I'm guessing you can't just check the harness for power.
  4. #4 Re: Factory Amp in '97 GP Coupe
    Willoughby, Ohio
    just make sure all your connection are making good contact and that all positive and negative wires are correct on the rear speakers. and that the harness on the amp isnt screwed up
  1. 01 Gp gt vs 07 or 08 altima coupe 2.5s vs infiniti g35 coupe
    By grandprixgt in forum Track Sessions and Kills
    Last Post: 02-26-2012, 05:56 PM
  2. Factory alarm for 98 GTP
    By tjvdubsport in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2009, 09:39 AM
  3. Factory amp in 2004 GP GT
    By flooger in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2009, 05:04 PM
