Thread: Speakers Loud Popping
Results 1 to 6 of 6
  1. #1 Speakers Loud Popping
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    Alright - so this just started happening and it starts at random. I have a 97 GTP.
    So I start the car and all of a sudden the rear speakers start popping loudly, like REAL loud. The music still plays very clearly with no problems, I can even mute the music but the popping is still there. The only way to get rid of the popping is to 1. turn off the radio or 2. it just will stop sometimes if I restart the car.
    Before I open it all up and check it, I wanted to know if this was a problem seen before and what it would be. Any input would be great. Thanks.
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  2. #2 Re: Speakers Loud Popping
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I had the same problem in my Prelude and it turned out that I pinched a wire going to my front stage and it was touching metal and grounding out. Was an easy fix but a big pain in the rump hunting down the source. I would retrace all wires and checkem closely. Good luck
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  3. #3 Re: Speakers Loud Popping
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    yeh i would say something to do wit the ground....i had a bad ground for my amp and the subs would make a poppin noise
  4. #4 Re: Speakers Loud Popping
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Are the speakers amplified externally or are they running off of the radio's power? If it is running off of radio power, is it a stock radio or aftermarket?
    Is the loud popping noise causing all music to stop playing through the speaker, or does it play music and still pop while its doing it?
    It is probably the positive speaker wire touching the negative speaker wire or vice versa and causing distortion (the popping noise) But there are other factors that I wouldn't rule out.
    -Steven-
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  5. #5 Re: Speakers Loud Popping
    Feb 2008
    Wisco
    Everything is stock on the vehicle. Stock radio running stock speakers.
    The music still plays while the popping sound is going on. Also the popping is at random, and doesn't always happen... but its still pretty annoying when it starts up.
    I agree that it could be something with the ground or the wires touching... so this weekend I'll have to track down the wires to make sure everything is legit.
    Do I need to do anything special to remove the rear speakers? Just for a heads up if its a pain to track down the wires. Thanks.
  6. #6 Re: Speakers Loud Popping
    Saraland Alabama
    you should be able to see the wires from the trunk
  1. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  2. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
  3. Any way to make 6 1/2 speakers fit?
    By Deezul_AwT in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2008, 11:03 PM
  4. Whats with all these new GP forums popping up?
    By Fish in forum Off Topic Discussion
    Last Post: 12-22-2007, 03:44 PM
