Re: WTF is wrong now? 99 GTP
98GTPCALGARY
Just orderd it with 3 day shipping. Ill let you know how it goes.
Well got my lights fixed...turns out it was a fuse, go figure. Never seen a blown fuse cause so many problems at once. Also took the DIC out and took it apart, everything looks good but it still dont work, just flash's. Also noticed once I turn the key to the run position its about 9 seconds until it begins to flash, unless I start the car and move it then it begins as soon as I move the car.
anybody?? cmon this cant be the only time this has happened...
Thats flipping crazy it was a fuse, I really am not liking all these electrical issues im having with this thing. I hope this pcm fixes it. Did you pull all your wheels and check your wheel sensors, I looked at the schmatics and every entire thing goes to the dic.
LSXHP
Its happend alot just everyone has a different route to fixing theres. one tiny thing can throw the whole dic off.
Boosted98Gtp
No, i dont even know what a wheel spped sensor looks like let alone what to look for or even what it really does, what should I look for?
Boosted98Gtp
Sounds like a pita :th_nervous:
When you were at the car wash did your pressure wash the engine? If you did then you more than likely got some water into some of the connections to the abs module or harness which is probably why you are getting all these issues
LSXHP
The speed sensor is in your wheel bearings. if you look behind your brake caliper their should be 2 wires somewhere in there, check them for cracks or wear spots, and maby if they just got unplugged. all 4 wheels have them, it is part of the abs system, check them all.
sic6
no, was auto wash. Fixed the headlights now its just the dic, but this went bad a while back. At first it was intermittent then got more and more freqent now its constant.
98GTPCALGARY
ill check that out this week, thanks. Would one of those cause the entire dic to flash all the time though?
Mh dic just started working out of the blue today. I have no idea what to do with this thing.
Boosted98Gtp
Thats messed up, mine used to work then it would flash all the time then flash and got more frequent until now its all the time.
Yeah i know. I suppose ill let you know if my pcm fixes my abs and tcs light. they still could possibly be linked.
Boosted98Gtp
The TCS is because of the abs not working, I can almost guarantee it! I had wires broken on a wheel sensor, and my abs light was on, and the tcs as well, when I changed the wheel bearings (speed sensors) They both went off, and now my tcs works properly again. There was a thread here somewhere that explains how to test you abs system for bad wires and such.
98GTPCALGARY
So its probably safe to say thats not the problem with mine because my abs works fine right?
98GTPCALGARY
I have omhed out the wheel sensors, and check all the wires. I hooked a abs scanner at work to it and it wouldnt even communicate. So thats where i started throwing pcm into the hwhole thing. considering my dic wasnt working either.
LSXHP
Yeah i would say your wheel sensors are fine!
Boosted98Gtp
any other ideas then?? im lost on this dic thing:confused:
ya, the dic thing, could all be a computer (pcm) problem. Do you know anybody with a car that is the same as yours? (that is close by) a cheap test would be to swap out the pcm, but to do that you still gotta do a CASE learn. so check into the cost of that in your area. I searched around, when I got my INTENSE PCM, and most shops were $100 and up, but I got a little GM shop to do it for $46.
