Thread: Car Audio Help
Results 1 to 20 of 28
  1. #1 Car Audio Help
    Oct 2011
    Illinois
    I have a 99 grand prix se with the bose audio system. I recently hooked up a new radio. Everyhing works except the sound. There's one input that plugs into the factory radio,that i can't plug into the harness kit,and the harness kit is the correct one. It's a red wire with a black and red input on it.I think its the plug that controls the sound and i can't figure out where it goes. Do i have to splice it or what??? Help!!!!
  2. #2 Re: Car Audio Help
    See the pink wire on..oh geez pin 7 or pin 1 of that small harness. Power it off the amp turn on from the radio.
    You'll have sound once you power the stock amp.
  3. #3 Re: Car Audio Help
    Oct 2011
    Illinois
    I just installed a new radio and removed the factory one. I haven't installed a amp or sub woofers yet. The harness has no pink wire at all.
  4. #4 Re: Car Audio Help
    What color wires are in that small connector on pins 1 and 7?
    Bose has a factory amp. Which requires power or you get no sound.
  5. #5 Re: Car Audio Help
    Oct 2011
    Illinois
    I have a picture of the harness kit,but it won't let me upload it,but the wiring kit i got has the connector on one end and the wires out the other. There isn't a small connector attached.
  6. #6 Re: Car Audio Help
    In your first post you said
    "There's one input that plugs into the factory radio,that i can't plug into the harness kit,"
    That "input".. is likely the power to the amp. I assumed it was a 7 or 9 pin connector that connected in about the middle of the radio. No need to give me a picture. I understand the issue... I think lol
  7. #7 Re: Car Audio Help
    Oct 2011
    Illinois
    Yup it connects on the middle of the factory radio.
  8. #8 Re: Car Audio Help
    Oct 2011
    Illinois
    I got the wrong harness huh? Went to 3 stores and they all said it was the right wiring kit.
  9. #9 Re: Car Audio Help
    Nope..you got the right harness. They don't make one for the seperate connector you have.
    I have a spare connector laying around here somewhere that I take wires out of to add to their connector and put the wire into it. Then it's all on one connector.
  10. #10 Re: Car Audio Help
    Oct 2011
    Illinois
    So what do i need to do to get sound?
  11. #11 Re: Car Audio Help
    Power the factory amp.
    What color wires are in that little connector?
    You need to put your remote amp turn on wire from the radio to the amp turn on typically.
  12. #12 Re: Car Audio Help
    Oct 2011
    Illinois
    Little connector? Just got one big connector.Sorry i just wanna make sure i get this right...lol
  13. #13 Re: Car Audio Help
    Dude..your killing me.
    You should have had
    one BIG connector on the factory radio
    One little connector on the factory radio
    One antenna wire on the factory radio
    Now you hooked up all the wires from the factory big connector to your new headunit connector
    You hooked up the antenna to your new head unit.
    See what I'm saying.. you left out the little guy.
  14. #14 Re: Car Audio Help
    SE Level Member mosinnagant's Avatar
    May 2011
    edgewood
    bill mine had some sort of box that had to be put in like a interface or something. i have a kedwood in mine.
    2007 Grand Prix GT - Green Filter Cone Intake, 180 F Thermostat, EGR Delete, Overkill Custom Tune, Muffler Delete with Thrush Glasspack res swap, Kenwood head unit
  15. #15 Re: Car Audio Help
    Yours is not a 99
  16. #16 Re: Car Audio Help
    May 2011
    edgewood
    i know i didnt know if he needed one too or if it was a direct hookup
  17. #17 Re: Car Audio Help
    Oct 2011
    Illinois
    Lol ok. The only wire in the little connector is red.
  18. #18 Re: Car Audio Help
    Your just trying to make this more difficult. Life was easy in 99
  19. #19 Re: Car Audio Help
    Quote Originally Posted by Torell10 View Post
    Red means power.
    That wire leads to the amplifier. Take the blue wire from your amp remote turn on from your new head unlt and hook it to that wire.
    Then send money to me via paypal for pain and suffering.
  20. #20 Re: Car Audio Help
    Got the friend request. I assume it worked?
  1. New audio setup! JL Audio
    By GP JLM in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 12:27 AM
  2. 04 GTP Audio Help
    By CJE in forum Audio, Security & Visual Electronics
    Last Post: 05-11-2010, 09:31 PM
  3. Help car audio
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2009, 05:27 PM
