Thread: What can I use to fix side skirt panels
Results 1 to 4 of 4
  1. #1 What can I use to fix side skirt panels
    SE Level Member FlaminWhite97GTP's Avatar
    Nov 2009
    Monee, IL
    My side skirt door panels are starting to pop out on the side of my Coupe Grand prix. What can I use seal it back to the door. Should I use Caulk or some type of super glue? what
    176K Miles, Things Done: 25K Tranny, VC & LIM Gaskets Replaced, synthetic fluids all around.
    Mods to come: CAI, Headers, Roller Rockers, U-bend & DP Delete, etc
  2. #2 Re: What can I use to fix side skirt panels
    wrong section?
    Double sided tape might be a bit more friendly when it needs to be taken off.
  3. #3 Re: What can I use to fix side skirt panels
    when my passenger side was falling off i used a small screw from the inside of the door. you can see where there are holes for it. that and double sided tape worked well.
  4. #4 Re: What can I use to fix side skirt panels
    Nov 2009
    Monee, IL
    ok thanks so much for the help guys & my bad for posting in the wrong section, I usually dont do that lol
  1. rocker panels
    By The1AndOnlyBug in forum 5.3L V8 (LS4)
    Last Post: 07-22-2009, 08:07 AM
  2. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  3. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  4. door panels
    By bb52190 in forum Visual/Body Modifications
    Last Post: 03-30-2009, 08:47 AM
  5. interior panels
    By Wadeb79 in forum General Tech Discussion
    Last Post: 10-15-2008, 07:02 PM
