Thread: Well I've got some luck
Results 1 to 8 of 8
dagger Well I've got some luck 02-15-2010, 07:42 PM
gpgt04 Re: Well I've got some luck 02-15-2010, 08:38 PM
dagger Re: Well I've got some luck 02-15-2010, 08:47 PM
gpgt04 Re: Well I've got some luck 02-15-2010, 08:51 PM
dagger Re: Well I've got some luck 02-16-2010, 08:35 AM
dagger Re: Well I've got some luck 02-16-2010, 09:26 PM
gpgt04 Re: Well I've got some luck 02-16-2010, 09:34 PM
dagger Re: Well I've got some luck 02-16-2010, 10:20 PM
  1. #1 Well I've got some luck
    CT
    So got my radio installed yesterday along with my sub and amp. Well today I go to lunch listen to my bumping tunes (lol). Shut the car off and everything was like normal. I admit I played with a few settings for the amp and audio and such. Nothing that would cause it not to work (BTW, its a DEH-P7600MP. Pretty sure atleast) and then I go and start my car to head home and its not turning on anymore or anything.
  2. #2 Re: Well I've got some luck
    GT Level Member gpgt04's Avatar
    MA
    the car doesnt turn on or the radio. if its the car the remote wire for the head unit isnt hooked up right and it drained your battery
  3. #3 Re: Well I've got some luck
    CT
    not the battery because its starting up just fine. Everything is still as it was wired before. I took the dash apart today and checked.
  4. #4 Re: Well I've got some luck
    MA
    did you check the fuse in the head unit
  5. #5 Re: Well I've got some luck
    CT
    Yup, it looked good. I didn't have the tool to check it but I took it out and inspected it and it looked good. I may just replace it anyways. I think tonight if I get a chance I'm going to find my tool to check fuses and see if all the ones for the car works.
  6. #6 Re: Well I've got some luck
    CT
    Just a little update:
    I looked and couldn't find a volt meter, so instead I plugged the old HU in and the lights light up when I turned on my lights but the display did not turn on and there was no music or sound. I did try to change it to many different channels. I then tried to bypass the harness because the wires were almost pulled out anyways but that did not change anything. Also I pulled out the fuse but dropped it and lost it, I even pulled back the rug because I have no idea where it is. So I have a feeling the constant power is working but the ignition wouldn't be turning it on. Right?
  7. #7 Re: Well I've got some luck
    MA
    theres a radio fuse in one of the cars fuse boxes too. i blew that one before. it should be say radio/amp.
  8. #8 Re: Well I've got some luck
    CT
    yeah thats the one I dropped. I'm going to put a new one in as soon as I can buy it.
  1. wish me luck
    By r33na in forum Off Topic Discussion
    Last Post: 11-10-2009, 06:53 PM
  2. Hello, and wish me luck
    By VerticalMK in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:33 PM
  3. My Luck
    By TheOtherNick in forum The Rant Forum
    Last Post: 01-15-2009, 12:03 AM
  4. Newbie, here about my bad luck...
    By zr861 in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 01:27 AM
  5. no luck tuning with vs cam >_<
    By fst in forum PCM Tuning
    Last Post: 09-18-2008, 12:40 PM
