Thread: Speed Sensor Wire in 2003
Results 1 to 7 of 7
grandprixgt1dejan Speed Sensor Wire in 2003 12-25-2009, 04:36 AM
gtpinsc Re: Speed Sensor Wire in 2003 12-25-2009, 09:42 AM
matt5112 Re: Speed Sensor Wire in 2003 12-25-2009, 11:22 AM
ninjazx6e Re: Speed Sensor Wire in 2003 12-28-2009, 08:57 AM
matt5112 Re: Speed Sensor Wire in 2003 12-28-2009, 10:37 AM
Toofastgs Re: Speed Sensor Wire in 2003 12-28-2009, 10:47 AM
grandprixgt1dejan Re: Speed Sensor Wire in 2003 12-29-2009, 08:44 AM
  1. #1 Speed Sensor Wire in 2003
    Windsor, On Canada
    Installing a Kenwood ddx6019 dvd with a kna dv4100 nav unit. Got a problem with the nav unit not giving turn by turn. I was told I have to connect the speed sensor wire to work properly, problem is i don't know the location of the speed sensor wire. If anyone has any sugestions or ideas please help. Thanks and Merry Christmas.
  2. #2 Re: Speed Sensor Wire in 2003
    Jul 2008
    sumter,south carolina
    speed sensor wires are directly behind the hub... its the only wire that plugs into the hub itself
    02 GTP with mods 05 GP for DD
  3. #3 Re: Speed Sensor Wire in 2003
    Umm... I'd vote thats total BS.
    Nav systems use GPS to calculate your position AND speed. It shouldn't need two things to tell it how fast you're moving. : \
  4. #4 Re: Speed Sensor Wire in 2003
    Michigan
    It is very normal for a Nav system to ask for a vss wire, in your car it happens to be dk. green and is Located at a 10 pin plug on the front of the drivers strut tower. There are two dk.green wires there, use the one in the corner of the plug.
  5. #5 Re: Speed Sensor Wire in 2003
    Checked it out... Very true, and very odd.
    Just remembered something, GPS isn't that accurate, so this just makes these nav systems that much better than the dash mount style.
  6. #6 Re: Speed Sensor Wire in 2003
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Most indash navs use the vehicles own speed sensor and the maps on the dvd to give directions then refer back to gps to realign itself it if is not with in a set calibration Also it uses this for when the unit cant pick up the gps signal. In all it is more accurate.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  7. #7 Re: Speed Sensor Wire in 2003
    Windsor, On Canada
    Thanks ninja, do you know if there is another location for this wire inside the car, maybe under the dash? I'll give it a try as soon as get some time on my hands and I'll let you know what happens. Thanks again.
  1. ABS speed sensor
    By m1sterb0b in forum Tires & Wheels
    Last Post: 12-21-2009, 10:14 PM
  2. Where is the Speed Sensor on a 99 Gtp
    By millertyme771 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 02:46 PM
  3. ABS Speed Sensor Issues
    By foghelmut in forum General Tech Discussion
    Last Post: 10-05-2009, 09:08 AM
  4. 2003 is not getting up to speed quickly
    By BUCKEYE in forum Introductions/Noob Questions
    Last Post: 08-10-2009, 12:32 PM
  5. High Ohms on MAF sensor wire
    By 2lagit2quit in forum General Tech Discussion
    Last Post: 07-01-2009, 10:36 PM
