Thread: Battery terminal
Results 1 to 3 of 3
  1. #1 Battery terminal
    SE Level Member Bueller's Avatar
    Nov 2009
    I've been having some difficulty getting the power wire onto the battery terminal because the stud is to short to incorporate a ring terminal. Is there a way to attach it or should I just order a new terminal (are there any that allow the stock stud to thread into it so I don't have to cut it off).
  2. #2 Re: Battery terminal
    Nov 2009
    Is a "long" terminal the answer I'm looking for? BlueWave GM Side Post Battery Long Terminal Gold
  3. #3 Re: Battery terminal
    that or hook it onto the positive on top of the fuse box. You might have to cut the plastic cover a little to get clearance but its cheaper than that $4 post.
  1. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  2. how can I remove a battery
    By cjmonahan in forum 5.3L V8 (LS4)
    Last Post: 09-10-2009, 08:22 PM
  3. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  4. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
