Thread: blown memphis 5 1/4
Results 1 to 19 of 19
gtpinsc blown memphis 5 1/4 12-06-2009, 02:42 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 02:36 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 05:49 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 06:10 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 06:15 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 06:34 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 08:46 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 08:49 PM
LowRidinCrew Re: blown memphis 5 1/4 12-07-2009, 09:06 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 09:12 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 09:14 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 09:15 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 09:13 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 09:18 PM
matt5112 Re: blown memphis 5 1/4 12-07-2009, 09:21 PM
gtpinsc Re: blown memphis 5 1/4 12-07-2009, 09:35 PM
matt5112 Re: blown memphis 5 1/4 12-08-2009, 02:36 PM
gtpinsc Re: blown memphis 5 1/4 12-08-2009, 07:03 PM
matt5112 Re: blown memphis 5 1/4 12-08-2009, 07:05 PM
  1. #1 blown memphis 5 1/4
    Jul 2008
    sumter,south carolina
    so for some reason one of my memphis 5 1/4's blew today at medium volume... powered by memphis M class 200w amp... other 3 channels had of course my other 5 1/4 and memphis M class 6x9's to the other 2 channels... what could have caused this... i ve had the volume turned way past where it was when it blew.
    02 GTP with mods 05 GP for DD
  2. #2 Re: blown memphis 5 1/4
    Question one: What is the rated RMS wattage of your tiny 5.25" speaker.
    Question two: what is the rated RMS wattage of your amp at the nominal impedance of your 5.25" speakers.
    If the answer to twice part one is less than part two, you blew it up because you put too much power to it.
  3. #3 Re: blown memphis 5 1/4
    Jul 2008
    i was waiting on u to chime in ....60 max 30 rms on the 5.25... not sure on the specs of the amp... its a memphis MC 200x4
  4. #4 Re: blown memphis 5 1/4
    Would you mind checking on the amp for the exact model number?
  5. #5 Re: blown memphis 5 1/4
    Jul 2008
    16-mca2004
  6. #6 Re: blown memphis 5 1/4
    Yeah if you were clipping your amp its possible. I'd get some 6.5's to replace them. Louder and higher power handling.
  7. #7 Re: blown memphis 5 1/4
    Jul 2008
    weird though... ive had them alot louder before... i stay constant 13.8 amps or better on power... sh*t happens.. how much work involved in installing 6.5's?
  8. #8 Re: blown memphis 5 1/4
    get some wood, cut it so it'll be able to be bolted to the holes for the plastic mount for the 5.25" and then cut a hole for the 6.5". Bolt woofer to wood and that to the door and viola.
  9. #9 Re: blown memphis 5 1/4
    Cleveland Heights, Ohio, United States
    how about ur hertz? (hz)
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  10. #10 Re: blown memphis 5 1/4
    Quote Originally Posted by LowRidinCrew View Post
    Wtf does that have to do with anything? The term would be frequency, and the frequency of what? If he had a high pass filter on, he'd be okay. But who even knows if he has subs.
  11. #11 Re: blown memphis 5 1/4
    Jul 2008
    X2... and yes i have 2 DD 1510's
  12. #12 Re: blown memphis 5 1/4
    hpf stays at 125
    and that shouldn't be an issue.
  13. #13 Re: blown memphis 5 1/4
    Jul 2008
    hpf stays at 125
  14. #14 Re: blown memphis 5 1/4
    Jul 2008
    i was X2 with u on ur previous post... and jus making a statement that i did have subs... no biggie.
  15. #15 Re: blown memphis 5 1/4
    I quickly realized how crude my last post was and changed it
  16. #16 Re: blown memphis 5 1/4
    Jul 2008
    its cool man...
  17. #17 Re: blown memphis 5 1/4
    Do you know what clipping sounds like? If not, it might be worth finding out because as soon as its clipping, you're just going to fry the next speaker you replace it with.
    How exactly did it blow? Try pushing down on the cone evenly on all sides and does it feel like its scratching? If so, you might as well cut the surround and the spider and pull the cone and former out to take a look at the voice coil. If its burnt or part of it has come off, you definitely gave it too much power.
    Note you WILL destroy it by doing that.
  18. #18 Re: blown memphis 5 1/4
    Jul 2008
    I know about pushing on the cone to check for blown/burnt coil... i checked that right after it blew... it sounds clean... no rubbing/scratching.
  19. #19 Re: blown memphis 5 1/4
    Take it out and check the leads, and then hook it up to an amp you know works.
  1. Memphis in May
    By SlowM90 in forum Shows and Events
    Last Post: 03-20-2009, 01:17 PM
  2. I miss living in Memphis, bikinis
    By Sabrewings in forum Off Topic Discussion
    Last Post: 12-08-2008, 11:52 PM
