Thread: Head unit complexities
Results 1 to 15 of 15
  1. #1 Head unit complexities
    SE Level Member mxthunder's Avatar
    NE Ohio
    Hey guys its me again.
    Wanting to put a different head unit in my 01 GTP, but I thought about a few things that could make this hard.
    1. Does the factory head unit perform alarm system/ Driver information center reset information ( oil life) functions?
    2. What are my options, if any to retain the steering wheel controls?
    3. any suggestions on a $150 head unit?
    Autolite 103 plugs, PRJ 8 gauge wires, 160* drilled tstat, Digital Horse Power Stage 1 PCM, Voltage booster harness, 3.25" pully, ZZP S.S. IC, Desert Fox tranny cooler/Thrasher shift kit, Wizair CAI, SLP headers/full system wrapped & coated, 3 gauge pods: A/F, Boost (16.5 lbs), comp G. 17" 04 GTP rims
  2. #2 Re: Head unit complexities
    MO
    each brand may have its own adaptor to allow steering wheel controls to still work. check for compatibility for the head unit. a 150$ head unit from where?
    <brandonl2000> LMAO D!!
  3. #3 Re: Head unit complexities
    NE Ohio
    Crutchfield, best buy, wherever.
    So the steering wheel controls arn't too big of a deal hmm.
  4. #4 Re: Head unit complexities
    West Side Michigan
    A place by me told me that some radio's actually have the adapter to make the steering wheel controls work, most don't though. They also said that if it doesn't work there was a part they could install in my car for $100 to make it work. I said no thanks and am with my stock radio right now. It does the job
  5. #5 Re: Head unit complexities
    Wooster, Ohio
    Quote Originally Posted by nawarkk View Post
    seems a little high but audio shops are normally a rip off anymore, but yea, if a unit doesn't have it already (most mid class don't) it can be added on to most. If your wanting to stay in that price range i highly recommend the lower end Eclipse or Kenwood Ex, I've had the same Eclipse for the last 9 years with NO problems (except had to have the laser aligned after a wreck) and it still sounds great and plays everything. I also have a mid class Kenwood in my S-10 and i LOVE it for the price, wish i would have went up to the Ex but still a great unit!
  6. #6 Re: Head unit complexities
    NE Ohio
    Yea, the stock head unit works great, with the exception of the CD player, that skips over every little bump i hit! Argh!
    Any suggestions on replacement speakers? I dont wanna replace the factory one ways with some two way speakers, im afraid that will mess up the dynamics.
  7. #7 Re: Head unit complexities
    All comes down to how much you want to spend.
    What you should look for are some 6.5" component speakers unless you wanna get creative...
    Keep the stock tweeter and find a good 4 Ohm 6.5" midwoofer within your price range.
    Madisound Store
    Parts Express: Featured Categories
  8. #8 Re: Head unit complexities
    MO
    what I would do is search crutchfield for a head unit you like anywhere from 200-250 dollars. Then go to my favorite website, sonicelectronix.com, and find it on there for as much as $100 cheapers.
  9. #9 Re: Head unit complexities
    NE Ohio
    Thanks for the help guys. I think I may upgrade the speakers first, but after doing some reading on here, that doesnt sound simple either.
    Given a factory bose system, can I simply drop in new speakers for the rear deck? 3/4 of them dont work at all, but I think the system still sounds pretty good (yeah I know).
    I would just like to get some references or kappas, but they are two way speakers, replacing one ways. Would that throw off the dynamic of sound?
  10. #10 Re: Head unit complexities
    Lets just say, full range in the rear deck is a bad thing if you care about sound quality unless you turn the volume WAY down on the rear speakers.
    If you're going to leave the bose system in, dropping new speakers wouldn't be a problem. You'd just have to snip off the connectors for the stock speakers and crimp some female spade terminals on it and plug it in.
    If you think thats too much, keep in mind to get the rear 6x9's out you have to take out the rear seats...
  11. #11 Re: Head unit complexities
    Jan 2009
    Tabor SD
    I read somewhere that the Bose speakers are 2 ohm and if you change the speaker to 4 ohm they will distort. I've never tried it out for myself but you might want to look into it. It might make it a little harder to install just any speaker and hook it up to the factory bose amp.
  12. #12 Re: Head unit complexities
    Quote Originally Posted by felonygtp View Post
    Two things: One, measure the resistance of the speakers, they're all different based on the car and how they're setup. and two, they'd only distort if you managed to clip it, which isn't possible because bose systems have soft clipping so you don't get terrible clipping.
  13. #13 Re: Head unit complexities
    NE Ohio
    So find some one way speakers to drop in? Or I suppose I could snip the connectors to the dome tweets that come in refrences etc and make them into a one way lol. I dont mind cutting the connectors, taking out the back seat? wow.... thats a fine piece of engineering for ya.. gotta love GM.
  14. #14 Re: Head unit complexities
    tangband makes some 6x9 subs if you were willing to get a small amp. You could have some nice bass from those, get some nice 6.5" for the doors and some tweeters for the stock spots. Wouldn't be that bad, at all.
  15. #15 Re: Head unit complexities
  1. New Head Unit
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:41 PM
  2. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  3. took out old head unit put in new one
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2009, 12:39 PM
  4. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
