Thread: Front Speaker Installation
Results 1 to 7 of 7
  1. #1 Front Speaker Installation
    SE Level Member SuperCharged0nE's Avatar
    Nov 2009
    KCMO
    I bought new front speakers for my 99 GTP and when I took the old blown speakers out I noticed there is a plug in terminal on the old set of speakers and seperate black and red wires soughtered onto it. The new speakers only have the clips where the new red and black wires go on...Do I just take the clip off the other set of wires and wire them in with the new clip with the other wires? Anyone have advise? Thanks
  2. #2 Re: Front Speaker Installation
    If you want the stock tweeters to still work, disconnect the wires from the plug and connect the positives to the positive on your new speaker and same with the negative.
    If I understand you correctly, simple answer would be "yes".
  3. #3 Re: Front Speaker Installation
    Nov 2009
    KCMO
    haha Ok thanks man! lol Just figured I'd check with someone with experience before I went cutting into factory wires
  4. #4 Re: Front Speaker Installation
    Let us know how it goes!
  5. #5 Re: Front Speaker Installation
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    bestbuy sells the adapters to convert the factory plug to a normal speaker plug
  6. #6 Re: Front Speaker Installation
    Normal meaning spade terminal?
    Or something more "heavy duty" like a spring-loaded terminal?
  7. #7 Re: Front Speaker Installation
    Nov 2009
    chicago
    spade plug
  1. HUD Installation- HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 10-08-2009, 08:03 PM
  2. Front Speaker Problems
    By Justin33 in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 06:46 PM
  3. Front Speaker Installation
    By justme in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2009, 03:27 PM
  4. sub installation
    By riley34 in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2008, 12:14 PM
  5. Speaker Installation??
    By ssm90GT in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2008, 08:16 PM
