I'm re-installing a Sony trunk-mounted CD changer in a 2002 GP (40th Anniv. edition). First installation (not by me) resulted in nasty lighting & instrument problems, fixed by replacing the ignition wiring harness at great $$. When this work was done, the CD changer was left disconnected. I now need to reconnect 2 wires, one 12v all the time and one to turn on the unit.
All I need to know is:
Where can I tap into the delayed accessory power line that lets the radio and power windows operate after ignition is off, but door hasn't been opened? I want something I can splice into that I can reach without disassembling the entire instrument panel. I've pin-poked into nearly every wire I can see at the bottom of the dash without finding what I need.
Any words of wisdom (including wire color)???
Thanks!
