Thread: new power wire
Results 1 to 14 of 14
  1. #1 new power wire
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    hi guys. when I return, I was thinking of getting a bigger box, retiring the zx1000 and putting a zx1500 on my 2 12" L7's. Anyone think i'll stll be straight with my 4g power wire? or will I need to go to a 0g. I don't wana cause a 0g is so big. but I'm also planning on doing "the big 3" under the hood for headlight purposes with the 1500watt amp.
    please comment insight on if a new power wire would be needed.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: new power wire
    Michigan
    You should have had bigger than 4awg with the 1000, so I would at least try to go up to a 2awg cable if you dont want to go to the 0awg
  3. #3 Re: new power wire
    Donating Users crshoveride's Avatar
    Pearl, MS
    I would def go with 0g
    1998 Grand Prix GTP Stock for now mods to come soon. Alpine 9885 head unit, 2 JLW3V2 10s, 2 Jensen 650x2 amps, and Tsunami wiring all the way around.
    Ladies and gentleman take my advice. pull down your pants and slide on the ice
  4. #4 Re: new power wire
    swift current,sask.
    Quote Originally Posted by offroadfury6 View Post
    0g is so big.
    Yes 0 is huge but should be safe with 2 gauge.
  5. #5 Re: new power wire
    West Side Michigan
    bro I would do 0 gauge. I have 0 for my mtx 6500d and I love it. I mean sure I could get away with a bigger gauge, but the better quality wires you put to your system the better it is imo.
  6. #6 Re: new power wire
    zr1 posted some **** about a chart that lists what power amps and what guage cable to use, find that and enjoy using science.
  7. #7 Re: new power wire
    Aug 2008
    Fayetteville, NC
    yeah i may just go the best route and go 0g but hell i cant see running that guage under the carpet without it showing lol. may run it under the car insted if I do that.
    ninjazx6e - I've never found any issues with my system as far as heat or distortion with a 4gauge and my zx1000 amp.
  8. #8 Re: new power wire
    Quote Originally Posted by nawarkk View Post
    quality of the wires.... as long as you're not buying wires that werent made to the specs of RCA wires and have protective jackets, they're all the same. Only big difference is the gauge.
    Lawl... Clippity clip clip clip is how 99% of people run their sound systems when showing off.
    Check your voltage loss, because thats what happens when you run a lot of current across a small wire.
    Cars are just ****ing retarded and run off of 12V/14.4V so the second you get reduced voltage you're losing power.
    half a volt at 100 amps is 50 watts lost to the power cable.
  9. #9 Re: new power wire
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    ive got a 0g running under my carpet and you wont notice it. i took it under the car to the hole in the passenger floor. then brought it in and ran it to the side of the seat and down a little then all the way back nd under the back seat. makes a hell of a diff. i ran my 3600w amp with a 4g and caught the wire on fire. bigger wire is way better.
  10. #10 Re: new power wire
    Michigan
    I dont doubt it, you can get away with it in most cases, just 4 awg is the minimum size for 1000 watts at 16 feet, so i would recommend going to at least 2 awg for the bigger amp.
    check this out
  11. #11 Re: new power wire
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by ZR1Vette09 View Post
    ^^ good info there
    found it!
  12. #12 Re: new power wire
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by TurboTrav View Post
    found it!
    according to that thing, i need a 1/0 guage wire. dam thats so huge.
  13. #13 Re: new power wire
    Cedar Rapids, IA
    thats what i have
  14. #14 Re: new power wire
    Aug 2008
    Fayetteville, NC
    ^^^True...I'll see when I get home.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  3. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  4. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
