The low beam works off of your factory wiring. The High uses the relay. So you need to check if your getting power to the relay, if you have the signal when you turn on highs and so on. Without me knowing how it is all wired its hard to say exactly what to look at. But loof at the fuse, power connection, ground connection etc.
