I have an 03 GTP and I have subs and amp hooked up as well... I didn't hook the power wire for the amp to the + Terminal of the battery because it doesn't have the posts ontop of the battery, and only has side posts, so I hooked up the power wire to the big black fuse box that has the red plastic + sign on it and behind that plastic piece there is a bolt where I hooked the amp power wire to, to that fuse box.. Could that be the reason why my battery is completley dead.. It's a brand new battery and only had the battery for a max of 2 weeks.. Please help.. Thank you to those that reply.
