Thread: head unit problem
Results 1 to 9 of 9
  1. #1 head unit problem
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    need some help with this.
    sometimes when im listening to a cd there will be a ticking noise coming from the speakers. it comes from all the speakers so i think its a head unit problem, and it only does it with cd's. doesnt happen with the radio or anything. any ideas what this could be?
  2. #2 Re: head unit problem
    SE Level Member lorenzojay's Avatar
    Roseville Mi
    just on the same cd or all of the cds you listen to?
  3. #3 Re: head unit problem
    Pittsburgh
    its pretty much just rock music, it happens on a bunch of different cd's
  4. #4 Re: head unit problem
    Roseville Mi
    stock unit or did you install your own radio? any amps hooked up or any new speakers?
  5. #5 Re: head unit problem
    Pittsburgh
    i bought it with a clarion h/u and infinitys up front and pioneers in the back
  6. #6 Re: head unit problem
    Roseville Mi
    well Id start by pulling the head unit and looking at how its hooked up and look for loose connections, if you have another head unit try wireing that up if the problem persists you might have blown speakers. does it have a poping sound with the car running or off? I know alternator whine is a common problem if you have a bad ground, you could also reground the head unit yourself if you wanted but Im betting that something is wrong with the cd player on the h/u its self..
  7. #7 Re: head unit problem
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    only rock? what is your eq set to do you have subs, have you been pushing the volume up a little to high?
  8. #8 Re: head unit problem
    Pittsburgh
    no not only rock. you can hear it a little better with rock. i was listening to some old school nelly hhaha on the way home from work today and it sounded fine, at some point the noise came back.
  9. #9 Re: head unit problem
    Cedar Rapids, IA
    sounds like the head unit is doing it i'd try a diff one and see what you get
  1. New Head Unit
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:41 PM
  2. aftermarket head unit radio reception problem
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 10:55 PM
  3. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
  4. took out old head unit put in new one
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2009, 12:39 PM
  5. new head unit
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 10:26 PM
