Thread: Let there be light...please
Results 1 to 20 of 35
  1. #1 Let there be light...please
    Aug 2008
    Petawawa
    Hey guys, My son drove my 2000 GP GT last night. He mentioned the frt headlights dont work (NOT THE BULBS). Then the dash lights dont work, nothing but the normal idiot lights that cycle during start up.
    I have checked as many fuses and relays as I could find, incl the park brake. Can anyone say they have had this problem...or an idea I may not have thought of.
    Thank you
    mongo
  2. #2 Re: Let there be light...please
    Joliet, IL
    not saying your incompitent but the dimmer is not adjusted all the way down right?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: Let there be light...please
    Apr 2009
    Wausau, Wisconsin
    Very easy thing to over look ^^
  4. #4 Re: Let there be light...please
    Aug 2008
    Petawawa
    Quote Originally Posted by BoostJunki3 View Post
    No problem, I hold several mechanics licences, its just that I am a military mechanic, no dimmer switch in a tank (well yeah there is but not the same)
    Unless I owned it I probably never worked on it...
    That is why I am asking, I understand too much, got no book, and never worked on it...
    I am thinking of the master light switch, and checking it with a meter, other than that and some other visuals I am almost done, without a having a book.
    thanks
  5. #5 Re: Let there be light...please
    Joliet, IL
    so the dimmer is not adjusted all the way down right?
    00 Silvermist GTP
  6. #6 Re: Let there be light...please
    Apr 2009
    Wausau, Wisconsin
    Update after dimmer switch?
  7. #7 Re: Let there be light...please
    London Ont, Canada
    incase you dont know where the dimmer is, it is on the left of the steering wheel below he gauge cluster.
    i hit mine all the time getting in and out and wonder sometimes why my interior lights arnt on at night lol then i remember...
  8. #8 Re: Let there be light...please
    Aug 2008
    Petawawa
    the dimmer switch has been ruled out. EO, lights on (manualy) no head lights, or dash lights...I placed a towel over the photo sensor and they still didnt come on.
    I pulled both lamps and they passed, as did the new spare bulb I installed as a control. I dont even get the high beam indicator light and it is brilliant blue when on.
    thanks
  9. #9 Re: Let there be light...please
    London Ont, Canada
    maybe a light control fuse??
  10. #10 Re: Let there be light...please
    Aug 2008
    Petawawa
    okay, I looked in the glove box and the eng comp, right inner fender. I looked and used my meter to test all fuses. nothing burnt. Are there any other locations for fuses I dont know? Is there one in the light switch.
    I only have so much time to work on it during the week, as most of you will understand.
    So if you have a bunch of ideas send them this way, the garage is waiting for her and I have nothing to do but get lights back on before fall/winter, when we need headlights in October...at lunch
  11. #11 Re: Let there be light...please
    London Ont, Canada
    as far as i know, glove and hood is all..
    if its ALL lights, interior and exterior then its gotta be something crazy stupid like a relay or something.. very odd..
  12. #12 Re: Let there be light...please
    Aug 2008
    Petawawa
    not quite all lights, I am going to do a compl check on what is and what is not working. But I am most certainly starting with the master light switch, park brake, DRL...
  13. #13 Re: Let there be light...please
    London Ont, Canada
    keep us updated.
  14. #14 Re: Let there be light...please
    Aug 2008
    Petawawa
    oops, yep checked the one in the glove box it was closed when tested.
  15. #15 Re: Let there be light...please
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by mongo View Post
    thanks
    i'm a army truck driver in a support company and there are dimmer's for blackout drive and such. should be the same for bradleys and M1A1's. just throwing 2 cents in there haha...
    good luck hope u fixed the problem, too lazy to read all the comments. i woulda suggested a fuse
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  16. #16 Re: Let there be light...please
    Aug 2008
    Petawawa
    Quote Originally Posted by offroadfury6 View Post
    Leopard C1 MBT has the high low beams on the floor. The other light are similiar to the M113.
  17. #17 Re: Let there be light...please
    Joliet, IL
    if the parking brake was partially engaged.... the lights your talking about wouldnt be on either just thought of that....your parking brake could be partially engaged and the dash indicator for the PB is out....
    00 Silvermist GTP
  18. #18 Re: Let there be light...please
    GT Level Member skidoojames151's Avatar
    seattle
    hey yea thats actually ^^^^^ a highly possible thing...your son sets the parking brake and forgets...sounds logical...and all symptoms sound like parking brake on...who wants to bet money???
  19. #19 Re: Let there be light...please
    Feb 2008
    But if the headlights come on by themselves, then that's not the problem. The parking brake triggers the headlights off, which keeps the dash lights off as well. When you manually turn on the headlights, the dash lights come on with them.
    I had a guy come in yesterday with the same problem in a Regal GS. It ended up being his dimmer switch had gone out. The radio and climate controls would black out, along with the dash lights not coming on, when the headlights came on, and adjusting the dimmer did nothing. He replaced the switch, and all was well.
  20. #20 Re: Let there be light...please
    Joliet, IL
    Quote Originally Posted by DanGTP View Post
    thanks
    00 Silvermist GTP
  1. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  2. Oil light
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2009, 01:21 PM
  3. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  4. SES Light
    By sws922 in forum General Tech Discussion
    Last Post: 11-01-2008, 01:30 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
