Thread: can i cut a wire in my dic so it wont dim?
Results 1 to 4 of 4
  1. #1 can i cut a wire in my dic so it wont dim?
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    i hate when i cut my fogs on the day and my dic dims so i was wondering can i just cut the dimmer wire and have full dic all the time? i know i can wire my fogs as drl. but if i do that i might just get the 04 gtp fogs and get somebody to retro some projectors in my fogs but use the drl/turn signals for my drl since they have that lovely orange color. but i aint going that far so please if anybody knows which wire to cut let me know
  2. #2 Re: can i cut a wire in my dic so it wont dim?
    St. Louis Mo.
    The dimming is not controlled by a wire, but it is control by Solar cell that reads the amount light and dims/brighten accordingly. There are writeups on how to replace the cel with a different to make it appear brighter, but I do not know of a way to make it full time bright.
    James Shafer
    St. Louis MO
  3. #3 Re: can i cut a wire in my dic so it wont dim?
    Jan 2009
    Atlanta, GA
    maybe in a newer gtp but when you cut the lights on in the daytime the dic dims 97-03. i know upper gm products dashes stay the same when the lights are turned on in the daytime but gp's arent in that category lol. im pretty sure a dimmer wire can be cut but i'll just rewire my fogs to be my drl
  4. #4 Re: can i cut a wire in my dic so it wont dim?
    GTP Level Member SuperSport's Avatar
    Michigan
    Sorry about bumping an old thread.
    When I added my DIC to my 01, I got the dimmer wire mixed with the chime wire, and mine wouldn't dim at night. I figured it out, but if you still want to cut a wire, take out your dic, and on the back, each wire is numbered on the plug. B1 should be a corner wire, it is gray in color, and if you cut it, the DIC will not dim. Your Eng/Met, Reset, Mode, and Trac/TCS button wont light either, so that may be a side affect, depending on who you ask.
    Good Luck.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. TXL wire necessary?
    By Toasty in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 12:18 PM
  2. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  3. Fly by wire T/B???
    By AKGTP in forum General Tech Discussion
    Last Post: 01-30-2009, 11:36 PM
  4. What wire turns on amp?
    By rtb in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 08:13 PM
  5. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
