Thread: Lets see if this can't be done
Results 1 to 8 of 8
  1. #1 Lets see if this can't be done
    CT
    So my aftermarket radio was taken out of my car, or rather stolen. The stock harness has 2 connectors. Ones better than the other, I'm looking to find out what the wires for the smaller connector do. I hooked up the only connector that was still there and the radio turned on and the time displayed and such but there was no sound so I'm guessing its for sound. Can anyone either get me a picture of what the harness looks like or tell me where the wires go. I'm trying to jimmy rig the thing so I can have a radio again.
  2. #2 Re: Lets see if this can't be done
    GT Level Member BoostedComp's Avatar
    Youngstown
    im 90% sure the function of the smaller one is the harness for the radio controls... i think that is what your asking sorry i dont have any pictures though
  3. #3 Re: Lets see if this can't be done
    Youngstown
    steering wheel radio controls that is**
  4. #4 Re: Lets see if this can't be done
    CT
    Ah ok, that would make sense. From what I found the pink one is for the amp turn on. I'll see what I can do for that one.
  5. #5 Re: Lets see if this can't be done
    CT
    ok here is something weird. If I just plug in the main connector the radio is on. Even with the car off. Why is that? I also have a picture of the connector thats all screwed up if you need me to post it up.
  6. #6 Re: Lets see if this can't be done
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    you probably have the power to a constant source instead of a switched source, which means it'll be on the entire time (and draining your battery).
    Google the wiring colors, and you'll be able to figure out what each wire is. You may even get a couple of pics in the google search that'll help if you're lucky. You can also search on here too.
    Jesse
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  7. #7 Re: Lets see if this can't be done
    CT
    thats the thing as of right now its the stock main harness going into it. I don't know how this is on all the time. Thats whats weird. I'm trying to just put the factory radio back in with the factory wiring. Now the wiring is a little messed up so I'll get you a picture so I can show you whats up. As soon as I get it up I'll get a link over here for it.
  8. #8 Re: Lets see if this can't be done
    CT
    Ok there it is. You can see I have the main harness but there is that random wire thats like black and white or offwhite and black. I don't know what that goes to. The other ones are from the second harness.
    BTW, the reason it was on was because I had driven the car and not opened the door and plugged the radio in lol. Someone on the other forum thought of that.
  1. Lets take a head count here!
    By gmboy in forum Canada
    Last Post: 12-29-2017, 09:11 PM
  2. Lets take a vote
    By RedLedbetter in forum Tires & Wheels
    Last Post: 04-04-2009, 11:41 AM
  3. GA-Lets take a head count!
    By TDCRacing in forum Southeast
    Last Post: 01-24-2009, 01:15 PM
  4. Lets talk about temps!!!
    By Blown97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2008, 11:36 AM
  5. Lets discuss 8 rib conversions
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 01:28 PM
